I was wondering if anyone has encountered this problem or has any ideas…
I was working on connecting my Fire TV to HA today. I have Debug Bridge installed, followed the instructions and for about 45 minutes it worked perfectly. (I even had the time to set up an automation to dim the lights when the TV was playing.)
Then about 45 minutes later it was showing as unavailable. The ADB log shows continuous timing out. I then restarted HA and the TV completely disappeared on the UI. Screenshot of logs:
It seems like the most likely culprit is the TV is not getting continuous power. But besides just leaving the TV on, is there an easy way to do this? And would a power outage put me right back in this situation?
I appreciate the help in advance!
