Hi everyone,
I try to search similar issue as mine but I can’t find one. I have a couple of Aqara D1 wall switch Double and also Triple channel.
My issue, when i press to swtich ON and OFf manually on the swith, Home assistant not updating it at all for the Aqara D1 Tripple channel. However for Aqara D1 Double, it work fine when i manually press the the switch. In home assistant, it switch on and off instantly.
I need others input here wheter this is common issue with tripple channel switch or I can make it work with a setting or command?
Thanks in advance.
