Hi there!
I’m trying to get an ESPHome NTP server running using an Arduino Nano ESP32 and a GPS module.
As far as I can tell, the module should work given that it uses NMEA to communicate, but the only output I get is -1 for every reading even after the red light starts flashing, indicating a good satellite lock.
Here’s what I get in the logs:
[12:28:03][I][app:100]: ESPHome version 2024.7.2 compiled on Jul 25 2024, 20:36:57
[12:28:03][C][wifi:599]: WiFi:
[12:28:03][C][wifi:427]: Local MAC: EC:DA:3B:60:19:08
[12:28:03][C][wifi:432]: SSID: 'topsecret'
[12:28:03][C][wifi:435]: IP Address: 10.13.15.13
[12:28:03][C][wifi:439]: BSSID: FA:9F:C2:A4:68:E5
[12:28:03][C][wifi:440]: Hostname: 'gps-esp32'
[12:28:03][C][wifi:442]: Signal strength: -94 dB ▂▄▆█
[12:28:03][V][wifi:444]: Priority: -65.0
[12:28:03][C][wifi:446]: Channel: 6
[12:28:03][C][wifi:447]: Subnet: 255.255.255.0
[12:28:03][C][wifi:448]: Gateway: 10.13.15.1
[12:28:03][C][wifi:449]: DNS1: 10.13.13.253
[12:28:03][C][wifi:450]: DNS2: 10.13.13.254
[12:28:03][C][logger:185]: Logger:
[12:28:03][C][logger:186]: Level: VERY_VERBOSE
[12:28:03][C][logger:188]: Log Baud Rate: 115200
[12:28:03][C][logger:189]: Hardware UART: UART0
[12:28:03][C][uart.arduino_esp32:151]: UART Bus 1:
[12:28:03][C][uart.arduino_esp32:155]: RX Buffer Size: 256
[12:28:03][C][uart.arduino_esp32:159]: Parity: NONE
[12:28:03][C][captive_portal:088]: Captive Portal:
[12:28:03][C][web_server:173]: Web Server:
[12:28:03][V][mdns:120]: - _esphomelib, _tcp, 6053
[12:28:03][V][mdns:122]: TXT: version = 2024.7.2
[12:28:03][C][esphome.ota:073]: Over-The-Air updates:
[12:28:03][C][esphome.ota:078]: Password configured
[12:28:03][C][safe_mode:020]: Boot considered successful after 60 seconds
[12:28:03][C][api:139]: API Server:
[12:28:03][C][api:140]: Address: gps-esp32.iot.lan:6053
[12:28:03][C][api:142]: Using noise encryption: YES
[12:28:03][C][wifi_signal.sensor:009]: WiFi Signal 'Wifi Signal Strength'
[12:28:13][VV][scheduler:226]: Running interval '' with interval=10000 last_execution=220901 (now=230901)
[12:28:14][VV][scheduler:226]: Running interval 'update' with interval=20000 last_execution=213260 (now=233260)
[12:28:14][V][sensor:043]: 'Latitude': Received new state -1.000000
[12:28:14][D][sensor:094]: 'Latitude': Sending state -1.00000 ° with 6 decimals of accuracy
[12:28:14][VV][api.service:140]: send_sensor_state_response: SensorStateResponse {
key: 666130917
state: -1
missing_state: NO
[12:28:14][V][sensor:043]: 'Longitude': Received new state -1.000000
[12:28:14][D][sensor:094]: 'Longitude': Sending state -1.00000 ° with 6 decimals of accuracy
key: 2355190616
state: -1
missing_state: NO
[12:28:14][V][sensor:043]: 'Altitude': Received new state -1.000000
[12:28:14][D][sensor:094]: 'Altitude': Sending state -1.00000 m with 1 decimals of accuracy
key: 1141543723
state: -1
missing_state: NO
[12:28:14][V][sensor:043]: 'Satellites': Received new state -1.000000
[12:28:14][D][sensor:094]: 'Satellites': Sending state -1.00000 with 0 decimals of accuracy
key: 1135853463
state: -1
missing_state: NO
[12:28:14][W][component:237]: Component gps took a long time for an operation (106 ms).
[12:28:14][W][component:238]: Components should block for at most 30 ms.
[12:28:15][VV][scheduler:226]: Running interval 'update' with interval=30000 last_execution=204535 (now=234536)
[12:28:15][V][sensor:043]: 'Wifi Signal Strength': Received new state -93.000000
[12:28:15][D][sensor:094]: 'Wifi Signal Strength': Sending state -93.00000 dBm with 0 decimals of accuracy
[12:28:15][VV][api.service:140]: send_sensor_state_response: SensorStateResponse {
key: 890054251
state: -93
missing_state: NO
…and here’s my current config:
substitutions:
devicename: gps
hostname: ${devicename}-esp32
domain: .iot.lan
fqdn: ${hostname}${domain}
esphome:
esp32:
board: arduino_nano_esp32
variant: ESP32S3
framework:
type: arduino
version: 2.0.14
# Enable logging
logger:
baud_rate: 115200
tx_buffer_size: 512
deassert_rts_dtr: false
hardware_uart: UART0
level: VERY_VERBOSE
logs: {}
external_components:
source:
type: git
url: https://github.com/RobertJN64/ESPHome-NTP-Server
refresh: 30s
components: [ ntp_server ]
# Enable Home Assistant API
api:
encryption:
key: !secret api_enc_key
port: 6053
password: ''
reboot_timeout: 15min
safe_mode:
reboot_timeout: 5min
num_attempts: 3
ota:
- platform: esphome
password: !secret ota_password
version: 2
port: 3232
# MAC: ec:da:3b:60:19:08
wifi:
ap:
ssid: ${hostname} Fallback Hotspot
password: !secret fallback_wifi_password
ap_timeout: 1min
domain: ${domain}
fast_connect: true
passive_scan: false
enable_on_boot: true
networks:
- ssid: !secret wifi_ssid
priority: 0.0
use_address: ${fqdn}
captive_portal:
uart:
- id: uart_gps
rx_pin: GPIO6
tx_pin: GPIO5
baud_rate: 9600
# debug:
# direction: BOTH
# dummy_receiver: true
# after:
# delimiter: "\n"
# sequence:
# - lambda: UARTDebug::log_string(direction, bytes);
gps:
uart_id: uart_gps
latitude:
longitude:
altitude:
satellites:
ntp_server:
time:
- platform: gps
on_time:
- seconds: '*'
then:
- lambda: 'ESP_LOGI("gps", "%02d:%02d:%02d", id(gps_time).now().hour, id(gps_time).now().minute, id(gps_time).now().second);'
- platform: wifi_signal
name: Wifi Signal Strength
update_interval: 30s
# Included for Prometheus metrics below.
web_server:
# Activate prometheus /metrics endpoint
prometheus:
If anyone has any tips on where I may be going wrong, I’m all ears. Thanks in advance!
