Anyone else seeing issues with the automation configuration options becoming unresponsive? I’ve noticed this only recently with both automations and when trying to use a blueprint.
The issue presents itself as follows…
Create a new automation (or use a blueprint)
Lets me start to configure actions
Suddenly the "Add Action" button stops working. If you press it nothing happens
I’ve tried refreshing my browser, deleted cache, and restarted HA but still seeing the issue. I can’t see a particular thing that starts the issue. Its just I’ll go to click the “Add Action” button, often after successfully adding a prior action and suddenly, no response. The rest of the interface works just fine - I can back out, go to another part of HA, etc. Weird!
Which type of logs? Core, Supervisor? I’m not sure where UI issues in the automations screen would get logged!
Also, I just went back into it now and tried using a blueprint and of course, it worked just fine. This is the annoying thing, it seems to be random and intermittant!
