I am trying to setup an automation in Home Assistant, where if the TensorFlow component detects a person around any of the cameras, I want to trigger a 15 sec video recording, and send the same via Telegram.
The issue that I am having is that the 15s recording is initiated, but never written to disk.
I have verified the path where the stream recording is to be created, and the path is accessible from home assistant.
I am running Home Assistant v 0.97.2 in docker, on Ubuntu 18.04
here are the relavant parts in my configuration.yaml file
homeassistant:
whitelist_external_dirs:
- '/media'
- '/share'
stream:
camera:
- platform: generic
still_image_url: http://hauser:hapwd@camip:81/Streaming/channels/102/picture
stream_source: rtsp://hauser:hapwd@camip:554/Streaming/channels/101
The cameras are HikVision cameras, and I have verified the stream_source url by using the same in VLC to get a stream.
The cameras output a H.265 stream
The problem is that when I try using the service console to trigger the camera.recording service, or use the automation, the mp4 file never gets created.
Here is the call I am using to trigger the camera.record service -
service: camera.record
"entity_id": "camera.camgarage",
"filename": "/share/test.mp4",
"duration": "15"
I do not see any errors in my log file regarding the recording or stream components. I have verified that the stream is working as the camera.snapshot function does see the video correctly, and takes a picture at the same path (also done to verify that HA can write a file to the path).
Please guide me on what I am doing wrong.
