Got my Home Assistant working. but now i have a issue. try some basic scripts. But do not get to see on the home screen. i have added a couple of scripts. am i doing the scripts wrong or am i missing somthing completely.
Would really appricate some help on this as i would like to expand my horizon’s
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: -26.2309
longitude: 28.0583
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 1693
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Africa/Johannesburg
# Show links to resources in log and frontend
- introduction:
# Enables the frontend
frontend:
http:
# Uncomment this to add a password (recommended!)
# api_password: PASSWORD
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
#sensor:
platform: synologydsm
host: 192.168.2.254
username: admin
password: #######
monitored_conditions:
- cpu_total_load
- memory_real_usage
- network_up
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather Prediction
- sensor:
platform: yr`
I think you hit the wrong button or something. Highlight only the sections of the post that include code and nothing else, then press the code button indicated by the red box in the image:
homeassistant:
latitude: -26.2309
longitude: 28.0583
elevation: 1693
unit_system: metric
- introduction:
frontend:
http:
updater:
discovery:
conversation:
history:
#sensor:
host: 192.168.2.254
username: admin
password: Bl@ck!!
- cpu_total_load
- memory_real_usage
- network_up
logbook:
# Track the sun
sun:
- sensor:
platform: yr
Please highlight all of your code block and then press the button; it looks like you only caught the first line. It makes it hard for others to see where you might be missing something. Your code should look like this:
There are a few indentation errors in your configuration file that need to be fixed. Some examples: introduction cannot start with a dash - either remove the line altogether or remove dash and space; all of http, updater … history need to be left-bound without leading space; for your synologydsm sensor you actually need a line sensor: right before that again left-bound without leading space, and the sensor’s config parameters need to be indented correctly as shown in the documentation; and looking at the weather sensors: when setting up multiple sensors of different types, you should have another look at the documentation on how to structure the config file.
