I would like to switch over to Lovelace and use the front-end editor but somehow I reverie errors while I will edit a card.
I’m running on the latest version of Home Assistant and the following error will appear:
Error handling message: {'type': 'lovelace/config/card/get', 'card_id': 11, 'id': 17}
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/websocket_api/connection.py", line 65, in async_handle
handler(self.hass, self, schema(msg))
File "/usr/local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 267, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 589, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 427, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: expected str for dictionary value @ data['card_id']
ui-lovelace.yaml
Title: My Awesome Home
- title: main
icon: mdi:home
theme: LightTheme
cards:
- type: glance
title: Glance card sample
entities:
- light.bijkeuken
- title: Test
icon: mdi:home
theme: LightTheme
cards:
- type: glance
entities:
- binary_sensor.gang_bewegingsmelder
