I am trying to create an automation but it doesn’t seem to get triggered.
What I want:
I have a temperature sensor (Honewell Total Comfort)
In “lovelace” I can easily see the current temperature and that get’s refreshed every ten minutes
If the temperature drops below 22 degrees I want my Panasonic Aquarea to switch on
(Switching the Aquarea on is working well)
What have I tried:
Use Numeric state climate.living
below 22
Climate_set_temperature
living to 12
(when I manually trigger the automation the Set_Temparature works and is ONLY used as an easy readable sample)
The above Never gets triggered, I guess because I somehow must make the Automation read the state of the temperature?
I guess I need to create a script to be able to get a trigger?
Somehow just adding the following does not seem to receive a trigger:
In Lovelace I can see both the present temperature in “Living”
and set the desired temperature in “Living”
When I activate the Automation, the “SET” temparature drops to “12”
The thing I can’t get to work is receive the trigger.
So How dow I make Home assistant monitor the temperature (climate_living) (current_temparature)
and notice a change?
Your help is kindly appreciated
