Hi all. I replaced a dumb 3 way switch setup in my house with the Eaton RF9640 master dimmer and Eaton RF9642 accessory switch. I had no issue including them to my Z-Wave network and then associating them using zwavejs2mqtt. What i did was added group2(on/off) and group3(dimming) to the accessory switch’s associations with the master switch as the target. It seems to work but there’s this annoying issue where the accessory doesn’t get updated with the master. For example, if the accessory is off and the master is on, I have to press the accessory twice. So to fix this, i go back into zwavejs2mqtt and add group 2 and group 3 associations for the master with the accessory as the target. This kind of worked a few times but then eventually i lost the abillity to dim from either of the switches. Turning power off to the switches seems to reset them and they work again for a little bit.
It seems like the switches get stuck in an association loop until i power cycle them. I know with inovelli they have a parameter you can set that prevents these loops but i don’t see any such thing for Eaton switches. Anyone ever experienced this?
