Hi all,
HA 2024.3.2, ESPHome 2024.2.2 running on RPi 4 4Gb RAm, the device named balcon-1 is an esp8266 - yaml file is below.
esphome:
friendly_name: Balcon-1
esp8266:
board: nodemcuv2
i2c:
sda: D2
scl: D1
scan: true
wifi:
ssid: !secret wifi_ssid
domain: .mylan.url
The problem is that updating ESPHome from 2024.2.2 to 2024.3.0 leads to this error(s)
INFO ESPHome 2024.3.0
INFO Reading configuration /config/esphome/balcon-1.yaml…
INFO Starting log output from 192.168.92.140 using esphome API
WARNING Can’t connect to ESPHome API for balcon-1 @ 192.168.92.140: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address=‘192.168.92.140’, port=6053))]: [Errno 113] Connect call failed (‘192.168.92.140’, 6053) (SocketAPIError)
INFO Trying to connect to balcon-1 @ 192.168.92.140 in the background
The device balcon-1 became offline. Ping it by name in ok, the system knows who is balcon-1;
the difference is is that after upgrade it’s not responding
I’ve tried deleting and recreating the device from HA, initialising with ESPHome Web, restoring the working version HA+ESPHome and upgrade to ESPHome2024.3.0, then upgrading the
device … nothing worked.
I’m ok with ESPHome2024.2.2, but however … so if anyone has ideeas, I have time … or wait for ESPHome2024.3.1 (I don’t trust .0 versions … too much)
Thank you for reading this.
