Issues with HA Supervised install on Debain 11
So, im having issues with installing HA supervised on Debain 11.
The install all goes well, however it just does not seem to start? No errors, nothing. It says the instance will be available at xx:xx:xx:xx:8123 but it just never is?
Any ideas?
Also, are there any better ways to install the HA supervised then using the .deb installer? I swear last time it was not this hard, I just used a docker container?
Please check the log file under /usr/share/hassio/homeassistant/home-assistant.log, you will find some useful information there
Install HAOS in a VM like VirtualBox.
Here is my log. Looks like its failing to get a IP address? Debain has a IP via DHCP and has internet access.
2023-01-13 03:16:38.568 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:17:06.710 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=20 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=20, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 37782)>
2023-01-13 03:17:08.576 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:17:38.577 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:18:08.579 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:18:38.581 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:19:06.710 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=20 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=20, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 37782)>
2023-01-13 03:19:08.583 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:19:38.586 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:20:08.589 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:20:38.592 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:21:06.711 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=20 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=20, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 37782)>
2023-01-13 03:21:08.596 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:21:38.600 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:22:08.602 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:22:38.607 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:23:06.712 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=20 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=20, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 37782)>
2023-01-13 03:23:08.611 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:23:38.615 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:24:08.618 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:24:38.622 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:25:06.713 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=20 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=20, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 37782)>
2023-01-13 03:25:08.624 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:25:38.627 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:26:08.628 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:26:38.632 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:27:06.715 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=20 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=20, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 37782)>
2023-01-13 03:27:08.634 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:27:38.638 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:28:08.640 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:28:38.643 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:29:06.717 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=20 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=20, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 37782)>
2023-01-13 03:29:08.646 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=27 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=27, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 57315)>
2023-01-13 03:29:38.649 ERROR (MainThread) [async_upnp_client.ssdp] Received error: [Errno 101]
