I just noticed that any ‘setpoint’ call from HASS actually does not register in the associated thermostat in VERA and therefore does not actually change the setpoint.
If I change the setpoint in Vera it registers in HASS, so that works. Also all other vera measured variables related to this thermostat register correctly in HASS,
I only use HASS to override my thermostat program so I have no idea when this behavior was introduced.
I only have this behavior with my opentherm (OTGW) thermostat (which is controlled by the opentherm gateway plugin) and not with the other Vera thermostats.
Before I file a bug request on Github; Does anyone see the same behavior?
