Issues with home assistant android app
This has just stared happening, i open the app and get a red warning screen. Clear that and the app opens for less than a second before crashing, I can load it in chrome and my partner can on his iPhone. Though he still gets the red warning screen that I’ve never seen before through the app.
Any ideas what could be causing it ?
What do you mean a red warning screen? That doesn’t sound right at all.
This is the warning
is your SSL certificate still valid?
Yes checked that, let’s encrypt logs show no action needed.
This also appears when I try to log in
that is an error only you can solve, the app is just telling you whats wrong. From the looks of it, are you blocking any API calls? If you have a proxy or firewall setup bypass it and try again to rule out issues there.
I started to run into the same problem out of nowhere today.
Were you able to solve the problem?
i have the exact same problem. Do you find the solution?
