Issues with Homematic IP Smoke-Detector Battery State
currently, I am facing an issue with my Homematic IP based smoke detectors.
since an update to the latest version 2021-10-4 everything was working normal, as far as I could see.
But since I’ve done an update of the HomeAssistant core and the OS, I can’t get the information of the Battery Status for most of the devices.
Right now, I have 7 Smoke-Detectors installed in different rooms.
As you can see, 6 of them reporting an Unknown state for the battery… only one of them is showing “normal”
grafik
But all of the devices seems to be available at all, since they do report a normal status
grafik
this is the working smoke detector in the Dev-Tools:
grafik
and this is the not working one:
grafik
Has anyone faced a similar issue recently?
Or does anyone have an idea what I could check?
The Homematic IP app doesn’t show any kind of issue… And I don’t beleive, that the batteries have failed (all of them were shown as normal shortly before… only one was unavailable - until I’ve made a restart of HomeAssistant.
But this time, even after several restarts, the status did not change.
