Hey all,
I’m having some issues after I get https going on my Home Assistant install.
Basically - I’ve got the certificates created via LetsEncrypt (I’ve got other certs I can use too, but this part is fine). I then update my configuration.yaml to include:
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
I’ve forwarded 8123 on my router to my HA server.
I give it a restart and everything is more or less fine. If I access my HA from an external location it’s all good and the certitificate is valid. However, the problem is that my iphone accessing the HA instance internally has an issue - and the iOS app refuses to accept an invalid certificate. If I browse from a desktop it’s all fine - I can ignore the warning - but not from the iPhone.
So, I thought the work around would be to put:
internal_url: http://[ip_address]:8123
in my homeassistant part of configuration.yaml.
However, it looks like HA doesn’t listen to that setting? As soon as I enable the keys https is the only option - even with the internal_url set to HTTP - I can only access the HTTPS address.
Due to my network setup - I can’t access the external url from within my network. Right now I think the only way to fix this would be to run a internal DNS server that serves the local HA IP address back internally to get around the cert error.
But just curious - has anyone go the internal_url option to work with http? Or got the iPhone app to accept a cert error?
