Anyone having issue (or successfully using) the latest Asustor NAS Home Assistant app? (i.e. version 2025.2.0.r01)
My setup is the Home Assistant app running on the Asustor Nimbuster 2 NAS. (the app runs the Docker version of HA, but published on the Asustor App Store)
I recently updated the app and now my Home Assistant crashes every 24-72 hours. Prior, it’d been running successfully for years but I’ve been making a lot of changes lately, so I’m not sure it is specific to the updated version.
In addition to updating the app version, I also recently added some Matter devices and added a few other integration like ZHA. Now it becomes unresponsive (quits logging, UI doesn’t respond, etc.) every couple days. I restart the container and it runs again for a day or 2. I’ve backed out several of the integrations that I’ve recently added and none seem to have made a positive difference.
Thanks for the suggestion. Unfortunately, I’ve read it many times, everytime it crashes. The last logged item is always different. Sometimes it is just a warning because an IP devices didn’t respond (like a TV that was off, etc.). Each time I try to address many of the last warnings or errors if present (within an hour before the crash) and it has yet to make a difference.
I wasn’t able to learn anything specific from the logs but based on the seemingly randomness of the crashes, I installed more RAM thinking it might be crashing due to insufficient RAM.
That seemed to do the trick. It has been running for a couple weeks now without crashing. The additional integrations and Docker containers must have took it over the edge.
Check if you have debugging inadvertently turned on for some integrations, causing memory and disk capacity bloat. How close to upper limits were you sailing before you added RAM?
Pretty sure I didn’t have any debugging on. I didn’t think to check before I upgraded. However, now if I go view the Hardware utilization in HA, I see that I frequently rise up to 2GB, which is 100% of what I used to have.
