Good afternoon,
I have managed successfully to point my internal IP to chosen domain with Duck DNS.
However, whenever I am trying to acquire a certificate to encrypt my connection with Let’s Encrypt I am out of luck. At the beginning I have tried to setup DuckDNS addon in Hassio with following configuration frontend crashes. My addon configuration:
In comparing your configuration.yaml to mine (I am using same tools as you), my base url does not have the colon or port number. My base URL is: ***.duckdns.org
I have tried all possible configurations but all of them caused same result - frontend crash.
Additionally I tried to use Putty to setup LetsEncrypt. I didn’t have any isues to setup DuckDNS. However, whenever I tried run certbot client wget https://dl.eff.org/certbot-auto
I received such error in Putty
