Issues with lights from vera after 0.47.1
After updating the Home Assistant to 0.47.1, all of my Vera lights have disappeared. I cannot find those devices in the dev console either.
Looking at the debug log I found following error
2017-06-22 13:37:09 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform vera
File “/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_component.py”, line 161, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/usr/lib/python3.5/asyncio/tasks.py”, line 400, in wait_for
return fut.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/light/vera.py”, line 24, in setup_platform
VeraLight(device, VERA_CONTROLLER) for device in VERA_DEVICES[‘light’])
File “/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_component.py”, line 331, in schedule_add_entities
self.async_schedule_add_entities, list(new_entities),
File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/light/vera.py”, line 35, in init
VeraDevice.init(self, vera_device, controller)
File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/vera.py”, line 144, in init
self.update()
File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/light/vera.py”, line 86, in update
self._color = self.vera_device.get_color()
File “/home/manan/.homeassistant/deps/pyvera/init.py”, line 655, in get_color
val = [cur.split(’,’)[c] for c in ci]
IndexError: list index out of range
Can anyone please help figure out what is wrong?
Thanks,
Manan
I’ve also got the same issues
This should be fixed in 0.49
Thank you for the awesome work !!!
Alan,
I am still getting the same error after upgrading to version 0.49. Below is the debug log
2017-07-16 23:18:24 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: 121,37,0, template: {{ value_json.rgb | join(’,’) }})
2017-07-16 23:18:24 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform vera
File “/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_component.py”, line 164, in _async_setup_platform
return fut.result()
File “/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_component.py”, line 344, in schedule_add_entities
File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/vera.py”, line 143, in init
self.update()
File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/light/vera.py”, line 85, in update
File “/home/manan/.homeassistant/deps/pyvera/init.py”, line 660, in get_color
It’s being investigated, here is an issue you can follow along with if needed:
Thanks Alan.
