Issues with migration (I think)
Hello all
I was running HA supervisor on a dedicated debian laptop. Since upgrading debian to bookworm i m having issues with automations.
Although i had other issues (such as z-wave devices) i managed to find solutions for them.
In on automation that i use to start my media player, the wake on lan no longer works
Here is a copy of the script
alias: wake htpc
sequence:
service: wake_on_lan.send_magic_packet data:
mac: 10:7B:44:50:33:80
broadcast_address: 192.168.1.119
mode: single
icon: mdi:countertop
in the past on the laptop i did not need to insert the broadcast_address. I inserted it here hoping this would resolve the problem…i did not
The issue, as far as i can tell is that when i run the script I get a false statement and the last 2 digits of the MAC address ar in red.
The mac address of the PC is correct and i verified it with the router map.
I tried to re-insert the MAC address to no avail
I entered the broadcast address to no avail
Each time I restarted Home assistant
I checked the target pc wake on lan function is is enabled and nothing was change on the target pc
What am i missing?
Thank you all for taking the time to respond to this post and help
Well, it’s wrong, so that definitely won’t help :wink:
I guess it should be
broadcast_address: 192.168.1.255
but that’s if both HA and the htpc have an 192.168.1.X IP address.
I don’t understand what you mean.
that’s not formatted, and by the looks of it, you’re mixing up a configuration and a script.
For wake on lan, you need to configure a switch, which doesn’t go in a script.
Thank you for your quick response
Nice to know about the broadcast address I will just delete it
With regards to the Mac address
alias: wake htpc
sequence:
  • service: wake_on_lan.send_magic_packet
    mode: single
The steps detail are as follows
Executed: 7 August 2023 at 10:10:51
Result:
params:
domain: wake_on_lan
service: send_magic_packet
service_data:
target: {}
running_script: false
And the step config shows
Everything in this script is in a black font with the exception of the number 80 which shows up in red.
This is why i say that this may be the problem
Is there something or a step missing?
read my post
Please, as already asked, format your post.
#this is to creates switches as per documentation
this switch is to turn on htpc
switch:
- platform: wake_on_lan
Sorry folks to be so obtuse. I do not know what you mean by “formatting”
The above is an exact paste of my switch as it shows up in my /config/switches.yaml with nothing less or nothing more
Again thank you for your patience and understanding
It’s in the FAQ and it’s stickied at the top of the forums.
