I’m trying to get HomeAssistant to work behind my nginx reverse proxy to go to https://mydomain.com/homeassistant as I’ve configured numerous other apps to, but cannot get it to work. I couldn’t find configs which weren’t only for the base domain online, so am sure that’s my issue. Below are the configs I’ve tried as well as a few other notes. Any help would be appreciated!
configuration.yaml(Appended everything below “scene:…” line - 192.168.0.35 is ip of nginx)
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
http:
# For extra security set this to only accept connections on localhost if NGINX is on the same machine
# Uncommenting this will mean that you can only reach Home Assistant using the proxy, not directly via IP from other clients.
# server_host: 127.0.0.1
use_x_forwarded_for: true
# You must set the trusted proxy IP address so that Home Assistant will properly accept connections
# Set this to your NGINX machine IP, or localhost if hosted on the same machine.
trusted_proxies: 192.168.0.35
When browsing to either path above (https://mydomain.com/ha/), it only partially loads the interface showing a black page with a grey bar at the very top
All reverse proxy settings for my nginx server are within the nginx.conf file
Is there any good documentation how to make this - I tried with the ngix proxy manger but faild now I wanted to try with the ngix reverse proxy but failing again
Just the mystuff.duckdns.org is all you need to register with duckdns, and if you’re using nginx proxy manager it will automatically generate a separate certificate for each of your subdomains. That’s how I currently have multiple services set up.
Thx for the repley - I tried this with the nginx proxy manager (npm) but I allway got errors creating the certificates -
I clould easily create the certificates for mystuff.duckdns.org -> but this was with the duckdns adon - any Ideas what I could try next ?
what is your http config in “configuration.yaml” ?
Hi!
I’am a studid f$%k! - I changed to router config - but forgot that I have a second rounter from the ISP!!! (I have 2 locations and made the first config at the other location) witch had no portforwarding I now configured the second router to the DMZ …
this has cost me hours!
I’m sorry that it now also cost you time too!
so what is my learning: Please check the ports - the error Messages are not very good!
again, you said you have bitwarden also running -
how did you get the certificates to bitwarden config - cause the proxymanger made new certificates for bw.mystuff.duckdns.org
thx and cheers
