I have a Vera Lite connected to my HA system. All of my Z-wave lights work great, however, any Virtual Switches or Insteon items I have (via the Altsteon daemon) do not function. HA sees the correct status of the light, but I cannot control with the switch. Right now I am using a command switch with HTTP commands to control the items in HA, but I cannot dim with that.
Let me know what other information I need to provide. Thank you in advance!
I’m having the same issue with my Vera Plus but as of yet I haven’t been able to figure it out. I kind of had an MQTT solution partially working but it was so hacked together and messy I abandoned it.
I am glad I am not the only one. My solution right now is to use a command line switch, and it is working. But I cannot dim. If HA had a command line dimmer, then I think I would be ok.
Next step is to set up OpenHAB with insteon, but I tried it a few days ago and couldn’t get it to work.
