Issues with rest based implementation of Simple EVSE Wifi
Hi, the following package is something I worked on for weeks and this has in fact worked just fine for 2 years. Since on off the last HA updates it does not work correctly anymore.
The package controls a Simple EVSE Wifi electric car charger.
When enabling the 2 scored out rest sensors, the charger will switch itself off, just 20-30 seconds after switching it on.
I have been disabling parts of the package in order to find out what exactly causes the issue. But no luck so far. It seems like doing multiple “getParameters” requests will fail. The issue is not related to the automations.
Does anyone know how to could limit the amount of “getParameters” requests and cache the data somehow and use that cached data to create the other sensors as a template sensor?
Given the time it took me to put this together I need some specific help, my programming skills are no that good :slight_smile:
#### Calling: http://192.168.207.98/getParameters gives me:
{"type":"parameters","list":[{"vehicleState":2,"evseState":false,"maxCurrent":20,"actualCurrent":18,"actualPower":0,"duration":0,"alwaysActive":false,"lastActionUser":"","lastActionUID":"","energy":0,"mileage":0,"meterReading":0,"currentP1":0,"currentP2":0,"currentP3":0}]}
#  Simple EVSE Wallbox Wifi package                         #
#  https://github.com/CurtRod/SimpleEVSE-WiFi               #
#### Set charging amp limits
input_number:
  evse_max_amps:
    name: "Maximale laadstroom"
    min: 6
    max: 20
  evse_max_charge_distance:
    name: "Maximaal bijladen"
    min: 20
    max: 270
    step: 10
#### Set max amps
rest_command:
  evse_set_max_amps:
    url: "http://192.168.207.98/setCurrent?current={{ states.input_number.evse_max_amps.state }}"
#### Activate EVSE
switch:
  - platform: command_line
    switches:
      evse:
        friendly_name: EVSE activeren
        command_on: "curl http://192.168.207.98/setStatus?active=true"
        command_off: "curl http://192.168.207.98/setStatus?active=false"
        command_state: "/usr/bin/curl -X GET http://192.168.207.98/getParameters"
        value_template: "{{ value_json.list[0].evseState == True}}"
#### sensors
  - platform: rest
    name: EVSE Vehicle state
    resource: http://192.168.207.98/getParameters
    value_template: "{{ value_json.list[0].vehicleState }}"
    method: GET
    timeout: 30
    force_update: true
    sensors:
      evse_vehicle_state_templated:
        value_template: >-
          {% if is_state('sensor.evse_vehicle_state', '1') %}
            Niet verbonden
          {% elif is_state('sensor.evse_vehicle_state', '2') %}
            Verbonden
          {% elif is_state('sensor.evse_vehicle_state', '3') %}
            Laadt...
          {% endif %}
        icon_template: >-
            mdi:car
            mdi:car-connected
            mdi:ev-station
          {% endif %}
  - platform: rest
    value_template: "{{ value_json.list[0].evseState }}"
    method: GET
    timeout: 30
    force_update: true
  - platform: rest
    name: EVSE Actual current
    value_template: "{{ value_json.list[0].actualCurrent }}"
    unit_of_measurement: "A"
    method: GET
    timeout: 30
    force_update: true
  - platform: rest
    value_template: "{{ value_json.list[0].actualPower }}"
    unit_of_measurement: "kW"
    method: GET
    timeout: 30
    force_update: true
  - platform: rest
    value_template: "{{ value_json.list[0].duration }}"
    method: GET
    timeout: 30
    force_update: true
    sensors:
      evse_duration_templated:
        value_template: >-
          {% set uptime = states.sensor.evse_duration.state | float * 1 / 60000 | int %}
          {% set minutes = ((uptime % 60) / 1) | int %}
          {% set hours = ((uptime % 1440) / 60) | int %}
          {% set days = (uptime /1440) | int %}
          {%- if uptime < 1 -%}
            Minder dan één minuut
          {%- else -%}
            {%- if days > 0 -%}
              {%- if days == 1 -%}
                1 dag
              {%- else -%}
                {{ days }} dagen
              {%- endif -%}
            {%- endif -%}
            {%- if hours > 0 -%}
              {%- if days > 0 -%}
              {%- endif -%}
              {%- if hours == 1 -%}
                1 uur
              {%- else -%}
                {{ hours }} uren
              {%- endif -%}
            {%- endif -%}
            {%- if minutes > 0 -%}
              {%- if days > 0 or hours > 0 -%}
              {%- endif -%}
              {%- if minutes == 1 -%}
                1 minuut
              {%- else -%}
                {{ minutes }} minuten
              {%- endif -%}
            {%- endif -%}
          {%- endif -%}
#  - platform: rest
#    name: EVSE Energy
#    resource: http://192.168.207.98/getParameters
#    value_template: "{{ value_json.list[0].energy }}"
#    method: GET
#    timeout: 30
#    force_update: true
#  - platform: rest
#    name: EVSE Charged Mileage
#    value_template: "{{ value_json.list[0].mileage }}"
#    unit_of_measurement: "Km"
#    method: GET
#    timeout: 30
##### customizations
homeassistant:
  customize:
    sensor.evse_vehicle_state_templated:
      friendly_name: Status
    input_number.evse_max_amps:
      friendly_name: Max. stroom
      icon: mdi:flash-circle
      unit_of_measurement: A
      persistent: true
    input_number.evse_max_charge_distance:
      persistent: true
    sensor.evse_power:
      friendly_name: Actueel laadvermogen
      icon: mdi:power-socket
    sensor.evse_duration_templated:
      friendly_name: Tijd geactiveerd
      icon: mdi:progress-clock
    sensor.evse_energy:
      friendly_name: Energie
      icon: mdi:download
    sensor.evse_charged_milage:
      friendly_name: Opgeladen bereik
      icon: mdi:map-marker-distance
    switch.evse:
      friendly_name: Lader activeren
      icon: mdi:ev-station
      persistent: true
##### Automations
automation:
  ## set max amps
  - id: evse_set_max_amps
    alias: EVSE set max amps
      platform: state
      entity_id: input_number.evse_max_amps
      service: rest_command.evse_set_max_amps
  - id: evse_inschakelen_na_2200
    alias: EVSE inschakelen na 22.00uur
      platform: time
      at: "22:00:00"
    condition:
      - condition: state
        entity_id: binary_sensor.leaf1mich_plug_status
        state: "on"
      - service: switch.turn_on
        entity_id: switch.evse
  - id: evse_uitschakelen_indien_bijgeladen_afstand_behaald
    alias: EVSE uitschakelen indien bijgeladen afstand behaald
      platform: template
      value_template: "{{ states('sensor.evse_charged_milage') |int > states('input_number.evse_max_charge_distance')| int}}"
    condition:
      - condition: numeric_state
        entity_id: sensor.evse_vehicle_state
        above: 1
      - service: switch.turn_off
  ## notify on full battery
  - id: evse_thuis_accu_vol
    alias: EVSE thuis notificatie indien accu vol
      platform: state
      entity_id: sensor.leaf1mich_charge
      to: "100"
      - service: notify.mobile_app_iphone_van_michel
        data_template:
          title: "Auto accu vol!"
          message: "Huidig accu percentage {{ states.sensor.leaf1mich_charge.state }}%"
            push:
              sound: "auto_volledig_opgeladen.mp3"
              content-type: jpeg
              url: !secret image_url_car-charge
  ## notify on charge start
  - id: evse_laadsessie_gestart_notificatie
    alias: EVSE laadsessie gestart notificatie
      platform: state
      to: "3"
        data_template:
          title: "Auto laad op"
          message: "Laadsessie Leaf gestart, accu {{ states.sensor.leaf1mich_charge.state }}%"
            push:
              sound: "auto_laad.mp3"
              content-type: jpeg
  ## notify on charge stop
  - id: evse_laadsessie_gestopt_notificatie
    alias: EVSE laadsessie gestopt notificatie
      platform: state
      to: "off"
    condition:
        below: 99
        data_template:
          title: "Auto laadsessie beëindigd!"
          message: "Laadsessie Leaf beëindigd, accu {{ states.sensor.leaf1mich_charge.state }}%"
            push:
              sound: "auto_laadsessie_beeindigd.mp3"
              content-type: jpeg
Hi michel, how did you fix it?
Based on time I want to be able to set the charging current so as not to melt my 35A fuse. I am new to home assistant and have no idea where to start.
I really don’t know anymore, it’s a long time ago. :slight_smile:
This is my current config:
input_number:
  evse_max_amps:
    min: 6
    max: 20
    min: 10
    max: 270
    step: 10
#### Set max amps
rest_command:
  evse_set_max_amps:
#### Activate EVSE
switch:
    switches:
      evse:
#### customizations
homeassistant:
  customize:
      persistent: true
      persistent: true
    switch.evse:
      persistent: true
#### sensors
  - platform: rest
    value_template: 'OK'
    json_attributes_path: $.list[0]
    json_attributes:
      - vehicleState
      - evseState
      - maxCurrent
      - actualCurrent
      - actualPower
      - duration
      - alwaysActive
      - lastActionUser
      - lastActionUID
      - energy
      - mileage
      - meterReading
      - currentP1
#      - currentP2
#      - currentP3
    sensors:
      evse_vehiclestate:
        value_template: "{{ state_attr('sensor.evse', 'vehicleState') }}"
        value_template: >-
          {% if is_state('sensor.evse_vehiclestate', '1') %}
            Niet verbonden
          {% elif is_state('sensor.evse_vehiclestate', '2') %}
            Verbonden
          {% elif is_state('sensor.evse_vehiclestate', '3') %}
            Laadt...
          {% endif %}
        icon_template: >-
            mdi:car
            mdi:ev-plug-type2
            mdi:battery-charging
          {% endif %}
      evse_evsestate:
        value_template: "{{ state_attr('sensor.evse', 'evseState') }}"
      evse_maxcurrent:
        value_template: "{{ state_attr('sensor.evse', 'maxCurrent') }}"
      evse_actualcurrent:
        friendly_name: Actuele laadstroom
        value_template: "{{ state_attr('sensor.evse', 'actualCurrent') }}"
        icon_template: mdi:power-socket
      evse_actualpower:
        value_template: "{{ state_attr('sensor.evse', 'actualPower') }}"
        friendly_name: "Actueel laadvermogen"
        icon_template: mdi:flash-circle
        unit_of_measurement: Kwh
      evse_duration:
        value_template: "{{ state_attr('sensor.evse', 'duration') }}"
        value_template: >-
          {%- else -%}
            {%- if days > 0 -%}
                1 dag
              {%- else -%}
                {{ days }} dagen
              {%- endif -%}
            {%- endif -%}
              {%- if days > 0 -%}
              {%- endif -%}
                1 uur
              {%- else -%}
                {{ hours }} uren
              {%- endif -%}
            {%- endif -%}
              {%- endif -%}
                1 minuut
              {%- else -%}
              {%- endif -%}
            {%- endif -%}
          {%- endif -%}
        icon_template: mdi:progress-clock
      evse_alwaysactive:
        value_template: "{{ state_attr('sensor.evse', 'alwaysActive') }}"
      evse_lastactionuser:
        value_template: "{{ state_attr('sensor.evse', 'lastActionUser') }}"
      evse_lastactionuid:
        value_template: "{{ state_attr('sensor.evse', 'lastActionUID') }}"
      evse_energy:
        friendly_name: Opgeladen vermogen
        value_template: "{{ state_attr('sensor.evse', 'energy') }}"
        icon_template: mdi:download
      evse_mileage:
        value_template: "{{ state_attr('sensor.evse', 'mileage') }}"
        icon_template: mdi:map-marker-distance
      evse_meterreading:
        friendly_name: Meterstand deze sessie
        value_template: "{{ state_attr('sensor.evse', 'meterReading') }}"
        icon_template: mdi:counter
      evse_currentp1:
        friendly_name: Amperage Fase 1
        value_template: "{{ state_attr('sensor.evse', 'currentP1') }}"
#      evse_currentp2:
#        friendly_name: Amperage Fase 2
#        value_template: "{{ state_attr('sensor.evse', 'currentP2') }}"
#        icon_template: mdi:power-socket
#      evse_currentp3:
#        friendly_name: Amperage Fase 3
#        value_template: "{{ state_attr('sensor.evse', 'currentP3') }}"
#### Automations
automation:
  ## set max amps
    initial_state: on
    - platform: state
      entity_id:
      - input_number.evse_max_amps
      - switch.evse
  ## turn on if plugged in at 22.00h.
    initial_state: on
      platform: time
      at: "22:00:00"
    condition:
    - condition: state
      entity_id: sensor.evse_vehiclestate
      state: "2"
  ## Turn off at set charged milage
    initial_state: on
    trace:
      stored_traces: 10
      - platform: state
        entity_id:
          - sensor.evse_mileage
    condition:
      - condition: template
        value_template: "{{ states('sensor.evse_mileage')|int > states('input_number.evse_max_charge_distance')|int }}"
    initial_state: on
      platform: state
      to: "3"
        data_template:
            push:
              content-type: jpeg
    initial_state: on
      platform: state
      to: "off"
    condition:
        below: 99
        data_template:
            push:
              content-type: jpeg
There is some Dutch in there, so you might need Google translate :wink:
I have a 1 phase charger, my father has a 3 phase charger, in this config phase 2 and 3 a commented out.
ah, if you improve it, please share!
Now i m using this
and i do some automation like you… but i want to switch to esphome component and use modbus to set and read parameter
do you have any experiences?
