I have been running the SensorPush temp and humidity sensors for a while now. But sometimes (I haven’t been able to correlate why this is happening), I get erratic readings. Note that I have 3 bluetooth dongles spread around the house listening for BLE – not sure if that’s related.
Usually after some time, the glitches stop. But it’s really annoying since I drive a thermostat with these readings … This is what I see as an example.
Note that the SensorPush app has a clean temperature signal, so I doubt it’s the sensor. Other values from the sensor (humidity, pressure) all fluctuate / glitch similarly.
