Issues with setting up remote access with swag
hello
i am trying to setup remote access using swag and duckdns, and am having issues. when i go to homeassistant.<subdomain>.duckdns.com, i get a nginx 403 error after signing in. i have tried disabling ip_ban in my configuration.yaml, and that did not work. i also do not have a ip_bans.yaml to check if my ip is there. any suggestions on how i could fix this would be appreciated.
thanks!
my docker-compose
services:
  portainer:
    container_name: portainer
    image: portainer/portainer-ce
    restart: always
    ports:
      - "9000:9000/tcp"
    environment:
      - TZ=America/Chicago
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock
      - /opt/portainer:/data
  swag:
    container_name: swag
    image: lscr.io/linuxserver/swag
    cap_add:
      - NET_ADMIN
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=American/Chicago
      - URL=<subdomain>.duckdns.org
      - SUBDOMAINS=wildcard
      - VALIDATION=duckdns
      - DUCKDNSTOKEN=<token>
    volumes:
      - /opt/swag/config:/config
    ports:
      - 444:443
    restart: unless-stopped
  homeassistant:
    container_name: homeassistant
    image: "ghcr.io/home-assistant/home-assistant:stable"
    volumes:
      - /opt/homeassistant/config:/config
      - /etc/localtime:/etc/localtime:ro
    network_mode: swag
    ports:
      - 8123:8123
    privileged: true
i created a user-defined bridge as swag for the home assistant and the other containers to connect to
my homeassistant.subdomain.conf
## Version 2023/02/05
# make sure that your homeassistant container is named homeassistant
# make sure that your dns has a cname set for homeassistant
# As of homeassistant 2021.7.0, it is now required to define the network range your proxy resides in, this is done in Homeassitants configuration.yaml
# https://www.home-assistant.io/integrations/http/#trusted_proxies
# Example below uses the default dockernetwork ranges, you may need to update this if you dont use defaults.
# http:
#   use_x_forwarded_for: true
#   trusted_proxies:
#     - 172.16.0.0/12
server {
    listen 443 ssl;
    listen [::]:443 ssl;
    server_name homeassistant.<subdomain>.duckdns.org;
    include /config/nginx/ssl.conf;
    client_max_body_size 0;
    # enable for ldap auth (requires ldap-location.conf in the location block)
    #include /config/nginx/ldap-server.conf;
    # enable for Authelia (requires authelia-location.conf in the location block)
    #include /config/nginx/authelia-server.conf;
    # enable for Authentik (requires authentik-location.conf in the location block)
    #include /config/nginx/authentik-server.conf;
    location / {
        enable the next two lines for http auth
        auth_basic "Restricted";
        auth_basic_user_file /config/nginx/.htpasswd;
        # enable for ldap auth (requires ldap-server.conf in the server block)
        #include /config/nginx/ldap-location.conf;
        # enable for Authelia (requires authelia-server.conf in the server block)
        #include /config/nginx/authelia-location.conf;
        # enable for Authentik (requires authentik-server.conf in the server block)
        #include /config/nginx/authentik-location.conf;
        include /config/nginx/proxy.conf;
        include /config/nginx/resolver.conf;
        set $upstream_app 192.168.XX.XXX;
        set $upstream_port 8123;
        set $upstream_proto http;
        proxy_pass $upstream_proto://$upstream_app:$upstream_port;
    location ~ ^/(api|local|media)/ {
home assistant configuration.yaml
http:
  ip_ban_enabled: true
  login_attempts_threshold: 5
  trusted_proxies:
    - 192.168.XX.0/24
    - 172.10.0.0/24
duckdns:
  domain: <subdomain>.duckdns.org
  access_token: <token>
Why are you enabling basic authentication above HA?
Bound to cause issue like the one you have (403 means “unauthorized”)
