Hi everybody,
I have a Shelly 1PM (which is connected to some lights) and I’m trying to control it with HA via MQTT.
I started by doing some tests with the MQTT Explorer and I was able to see the topics status changing whenever I toggled the input. Also, everything worked fine when I forced a command, using the explorer.
However, when I try to do the same using HA I face some issues. I’m able to send the “on” command but I never get the feedback of the state, this way I can’t send the “off” command.
My configuration.yaml is as follows:
light:
- platform: mqtt
state_topic: “shellies/shelly1pm-xx/relay/0”
command_topic: "shellies/shelly1pm-xx/relay/0/command"
payload_on: "on"
payload_off: "off"
qos: 1
Just for testing the state change, I did the following configuration, and I was able to see the state change feedback in HA, by toggling the 1PM input.
- platform: mqtt
qos: 1
I have the latest HA version and also Shelly 1PM latest firmware.
What am I doing wrong?
Thanks for the support.
