Sorry, I currently use Z2M not ZHA. In the official docs I see that that property can also have negative values: zigpy-znp/README.md at dev · zigpy/zigpy-znp · GitHub
If the transmit power is high, devices that are far from the coordinator (say 10m) will "hear" it as the loudest source from the local devices, therefore believe that is is really close, and will use it directly to transmit data. Problem is that the coordinator is actually far away and may not hear incoming messages; it is good at shouting, not good at hearing.
Z2M has an activity screen, don't know about ZHA. You can also use a specialized sniffer device and see the traffic in Wireshark.
Zigbee Map has support for ZHA. Disclaimer: I am the author of this integration: Zigbee Map - Visualize your mesh network
