Hi All
I’m getting a few issues with the Tado integration. I think that one has already been covered here where the temperature control is broken.
The other issue that I am getting is that whenever I make any changes to any of my thermostats it is set forever. For example if I turn off my aircon (automations do this when I turn the light for a room off) then in the tado app it says “until you cancel”. This means that my tado schedules no longer work and the aircon does not come back on at the set time.
I tried both NEXT_TIME_BLOCK and TADO_DEFAULT in the integration configuration but neither seem to make a difference.
Has anyone else seen this?
