I created Template Switch and Sensor to control the device with two Restful commands. Sensor works with 10-30 seconds delay of actual device state.
If I click turn on the switch, turn_on command work fine, but after few second switch runs into turn off state. After 10-30 seconds sensor became on, but switch’s state is still off. I expected that switch’s state will be the same as sensor state. What’s wrong?
- platform: rest
resource: http://192.168.88.4/admin/channelm1/get_params.cgi?rec_enabled
username: xxx
password: xxx
value_template: "{{ 'on' in value }}"
force_update: true
switches:
pearl2_rec:
value_template: "{{ is_state('sensor.pearl2_rec_enabled', 'true') }}"
turn_on:
service: rest_command.pearl2_rec_on
turn_off:
service: rest_command.pearl2_rec_off
rest_command:
pearl2_rec_on:
url: 'http://192.168.88.4/admin/channelm1/set_params.cgi?rec_enabled=on'
username: xxx
password: xxx
pearl2_rec_off:
url: 'http://192.168.88.4/admin/channelm1/set_params.cgi?rec_enabled=""'
username: xxx
password: xxx
