Currently running HASS 0.64.3 within a docker on Unraid.
I’m not quite sure when (e.g. at which HASS update) my Xiaomi Aqara Gateway stopped working, but I’m no longer able to render it within HASS.
My component info in configuration has remained valid, and I’ve verified the key is correct:
### Xiaomi Gateway ###
xiaomi_aqara:
discovery_retry: 10
gateways:
- host: 192.168.86.33
- key: 70g*********
I do get some errors within the .log file, with the last line indicating “KeyError: ‘key’”
File "/usr/src/app/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/local/lib/python3.6/asyncio/futures.py", line 327, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
future.result()
File "/usr/local/lib/python3.6/asyncio/futures.py", line 243, in result
raise self._exception
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/src/app/homeassistant/components/wink/__init__.py", line 312, in setup
pywink.get_subscription_key())
File "/usr/local/lib/python3.6/site-packages/pywink/api.py", line 577, in get_subscription_key
response_dict = wink_api_fetch()
File "/usr/local/lib/python3.6/site-packages/pywink/api.py", line 598, in wink_api_fetch
raise WinkAPIException("401 Response from Wink API. Maybe Bearer token is expired?")
pywink.api.WinkAPIException: 401 Response from Wink API. Maybe Bearer token is expired?
2018-03-04 15:49:36 DEBUG (SyncWorker_0) [homeassistant.components.xiaomi_aqara] Expecting 2 gateways
2018-03-04 15:49:36 INFO (SyncWorker_0) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 1)
2018-03-04 15:49:36 ERROR (MainThread) [homeassistant.setup] Error during setup of component xiaomi_aqara
future.result()
File "/usr/src/app/homeassistant/components/xiaomi_aqara.py", line 130, in setup
xiaomi.discover_gateways()
File "/usr/local/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 93, in discover_gateways
key = gateway['key']
KeyError: 'key'
Any suggestions of where / how to troubleshoot? I’ve googled around a bit and can’t find anything with the KeyError I’m getting.
