Issues with Zigbee radio on Yellow
I have been using my Yelow for about 4 months now. I have issues with the zigbee radio. When I connect devices they start going unavailable within hours. I have a Zigbee smart plug within a meter of the yellow so this could work as a router. Would Zigbee to MQQT help? When I connect my Sonoff stick it works great.
Try to follow this as best you can → https://community.home-assistant.io/t/guide-for-zigbee-interference-avoidance-and-network-range-coverage-optimization/515752
Also see → https://www.home-assistant.io/integrations/zha#defining-zigbee-channel-to-use
As well as follow this too → https://www.home-assistant.io/integrations/zha#best-practices-to-avoid-pairingconnection-difficulties
Thank you Hedda
My Zigbee radio in the Yellow is working great now
i connected a zigbee smart plug right next to the Yellow and this is acting as a mesh extender
Looking forward to Matter!
You made my day - thanks a lot!
  • Some battery-operated Zigbee devices are known to have problems with pairing if they have Low battery voltage.
    • Some people have reported replacing the battery on their newly received Xiaomi/Aqara devices solved pairing issues.
This did the Trick!
