I have a whole house fan (Airscape) that I can control from my ISY using the Airscape Polyglot nodesserver. While the device shows up in HA, it is only appearing as a sensor, not a switch or even better a fan device as I would expect. Do any of the ISY gurus have any idea how to make this appear as a fan and/or to write automation to send the proper commands to the ISY to control it? I have some existing automation that talks directly to the REST interface for the fan, but that’s rather kludgy when there is a nodeserver that can already do the work for me.
Here is how the fan appears in the node list from the ISY:
<node flag="128" nodeDefId="controller">
<address>n004_controller</address>
<name>Airscape Controller</name>
<family instance="4">10</family>
<parent type="3">40263</parent>
<type>0.0.0.0</type>
<enabled>true</enabled>
<deviceClass>0</deviceClass>
<wattage>0</wattage>
<dcPeriod>0</dcPeriod>
<startDelay>0</startDelay>
<endDelay>0</endDelay>
<pnode>n004_controller</pnode>
</node>
<node flag="0" nodeDefId="airscape2_F">
<address>n004_wholehousefan</address>
<name>Airscape WholeHouseFan</name>
</node>
(I’m assuming the issue is because it is reporting a type of 0.0.0.0)
And here is the information the ISY sees about the fan:
which does all show up in the sensor:
| Entity | State | Attributes |
| sensor.airscape_controller | 1 | custom_control_1: debug friendly_name: Airscape Controller |
| sensor.airscape_wholehousefan | 0 | temperature: 99°f custom_control_7: 0 custom_control_6: 0 custom_control_5: -99°f custom_control_4: -99°f custom_control_3: 0 cfm custom_control_2: false custom_control_1: true power: 78 watts time_remaining: 0 friendly_name: Airscape WholeHouseFan |
Just in case anyone has ideas for automation, here is the debug log of doing a “Speed Up” (which turns the fan on) and an “Off” from the ISY admin interface.
Sun 07/05/2020 18:26:08 : [D2D EVENT ] Event [n004_wholehousefan] [GV2] [1] uom=2 prec=0
Sun 07/05/2020 18:26:08 : [n004_wholehousefan] GV2 1 (uom=2 prec=0)
Sun 07/05/2020 18:26:18 : [D2D EVENT ] Event [n004_wholehousefan] [ST] [1] uom=56 prec=0
Sun 07/05/2020 18:26:18 : [n004_wholehousefan] ST 1 (uom=56 prec=0)
Sun 07/05/2020 18:26:18 : [D2D-CMP 005F] STS [n004_wholehousefan] ST op=6 Event(val=1 uom=56 prec=0) != Condition(val=0 uom=56 prec=0) --> true
Sun 07/05/2020 18:26:18 : [D2D-CMP 005F] STS [n004_wholehousefan] ST op=5 Event(val=1 uom=56 prec=0) >= Condition(val=1 uom=56 prec=0) --> true
Sun 07/05/2020 18:26:18 : [D2D EVENT ] Event [n004_wholehousefan] [GV2] [0] uom=2 prec=0
Sun 07/05/2020 18:26:18 : [n004_wholehousefan] GV2 0 (uom=2 prec=0)
Sun 07/05/2020 18:26:18 : [D2D EVENT ] Event [n004_wholehousefan] [GV3] [1000] uom=7 prec=0
Sun 07/05/2020 18:26:18 : [n004_wholehousefan] GV3 1000 (uom=7 prec=0)
Sun 07/05/2020 18:26:18 : [D2D EVENT ] Event [n004_wholehousefan] [ST] [2] uom=56 prec=0
Sun 07/05/2020 18:26:18 : [n004_wholehousefan] ST 2 (uom=56 prec=0)
Sun 07/05/2020 18:26:18 : [D2D-CMP 005F] STS [n004_wholehousefan] ST op=6 Event(val=2 uom=56 prec=0) != Condition(val=0 uom=56 prec=0) --> true
Sun 07/05/2020 18:26:18 : [D2D-CMP 005F] STS [n004_wholehousefan] ST op=5 Event(val=2 uom=56 prec=0) >= Condition(val=1 uom=56 prec=0) --> true
Sun 07/05/2020 18:26:18 : [D2D EVENT ] Event [n004_wholehousefan] [CPW] [157] uom=73 prec=0
Sun 07/05/2020 18:26:18 : [n004_wholehousefan] CPW 157 (uom=73 prec=0)
Sun 07/05/2020 18:26:18 : [D2D EVENT ] Event [n004_wholehousefan] [GV3] [1712] uom=7 prec=0
Sun 07/05/2020 18:26:18 : [n004_wholehousefan] GV3 1712 (uom=7 prec=0)
Sun 07/05/2020 18:26:19 : [D2D EVENT ] Event [n004_wholehousefan] [ST] [0] uom=56 prec=0
Sun 07/05/2020 18:26:19 : [n004_wholehousefan] ST 0 (uom=56 prec=0)
Sun 07/05/2020 18:26:19 : [D2D-CMP 005F] STS [n004_wholehousefan] ST op=6 Event(val=0 uom=56 prec=0) != Condition(val=0 uom=56 prec=0) --> false
Sun 07/05/2020 18:26:19 : [D2D-CMP 005F] STS [n004_wholehousefan] ST op=5 Event(val=0 uom=56 prec=0) >= Condition(val=1 uom=56 prec=0) --> false
Sun 07/05/2020 18:26:19 : [D2D EVENT ] Event [n004_wholehousefan] [CPW] [0] uom=73 prec=0
Sun 07/05/2020 18:26:19 : [n004_wholehousefan] CPW 0 (uom=73 prec=0)
Sun 07/05/2020 18:26:19 : [D2D EVENT ] Event [n004_wholehousefan] [GV3] [0] uom=7 prec=0
Sun 07/05/2020 18:26:19 : [n004_wholehousefan] GV3 0 (uom=7 prec=0)
Sun 07/05/2020 18:26:19 : [D2D EVENT ] Event [n004_wholehousefan] [CPW] [78] uom=73 prec=0
Sun 07/05/2020 18:26:19 : [n004_wholehousefan] CPW 78 (uom=73 prec=0)
EDIT: I should add, I can also make this work using ISY programs, but that only lets me turn the fan on at low speed and off, not control the speed. I can have a program like:
HA.fan / WHF / action
If
- No Conditions - (To add one, press 'Schedule' or 'Condition')
Then
Set 'Fans / Airscape Controller / Airscape WholeHouseFan' Off
Else
Set 'Fans / Airscape Controller / Airscape WholeHouseFan' Speed Up
