From the Community -> overview -> isy994 description:
**Example entry for configuration.yaml (if applicable):**
isy994:
host: !secret isy_url
username: !secret isy_username
password: !secret isy_password
isy_variables:
sensors:
- id: 23
type: 2
unit_of_measurement: '%'
device_class: 'battery'
binary_sensors:
- id: 14
type: 2
switches:
- id: 5
type: 2
When installed, this will be located in '/config/custom_components/isy994', you still need to add it to your 'configuration.yaml' file.
what’s confusing me is the last line starting with ‘When installed’. does this mean I have to have everything that is in custom_components/isy994 copied into the isy994: entry in configuration.yaml?
More explicitely, does every single item/sensor/whatever that appears in every file in:
have to be manually set up in the configuration.yaml?
I do have:
isy994:
and that seems to make the connection and the Lovelace UI gets populated, so I’m sure I’m missing the forest for the leaves here.
A little help? Thanks in advance.
CallMeClueless
