homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 0
longitude: 0
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: UTC
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
ignore:
- sonos
- samsung_tv
enable:
- homekit
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
panel_iframe:
configurator:
title: Configurator
icon: mdi:wrench
url: http://hassio.local:3218
# Example configuration.yaml entry
media_player:
- platform: plex
homekit:
isy994:
host: http://ipaddress:80
username: username
password: password
on the About page, I noticed that I’m getting an error:
Fri Sep 14 2018 17:39:54 GMT-0600 (Central Standard Time)
Error during setup of component isy994
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/isy994.py", line 380, in setup
use_https=https, tls_ver=tls_version, log=_LOGGER)
File "/srv/homeassistant/lib/python3.5/site-packages/PyISY/ISY.py", line 84, in __init__
self.nodes = Nodes(self, xml=self.conn.getNodes())
File "/srv/homeassistant/lib/python3.5/site-packages/PyISY/Nodes/__init__.py", line 52, in __init__
self.parse(xml)
File "/srv/homeassistant/lib/python3.5/site-packages/PyISY/Nodes/__init__.py", line 238, in parse
Group(self, nid, nname, members, controllers), ntype)
File "/srv/homeassistant/lib/python3.5/site-packages/PyISY/Nodes/group.py", line 43, in __init__
self.update()
File "/srv/homeassistant/lib/python3.5/site-packages/PyISY/Nodes/group.py", line 83, in update
if self.parent[m].status > 0:
File "/srv/homeassistant/lib/python3.5/site-packages/VarEvents/__init__.py", line 255, in __gt__
return self._val > other
TypeError: unorderable types: NoneType() > int()
If I understand correctly, it’s complaining about TLS,
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/isy994.py”, line 380, in setup
but your config says port 80, so HTTP without TLS. Is it possible that your ISY is using SSL/TLS (typically port 443), but you specified port 80 by mistake? I’m just guessing…
I have never setup SSL on my ISY. I have verified that I can get to my ISY by typing http://ipaddress:80 in a web browser. I can also get to it with https://ipaddress:443 in a browser. I tried using https://ipaddress:443, and adding the TLS version in my config file just to see, but I get the same error.
Also, when I check the config file, it doesn’t show any errors
Am i missing something? is there a reason im not getting any help? I’ve tried everything I can think of. Have also tried Hassbian instead of HASSio and i get the exact same error
The ignore_string ignores anything that starts with “z_ignore”. Im using this to ignore the “Auto DR” scene in the ISY. obviously i renamed it to “z_ignore Auto DR”
