ISY994 Migration Options
Hi all!
I have an ISY994 with a serial PLM controlling 3x Insteon 2477D dimmer switches (timers, Alexa integration, etc). Given the ISY is end-of-life, I’m ready to upgrade and exploring options. One such option is to replace the ISY994 with the successor device, eisy | home. That’s $290 plus $26 for the PLM adapter. Curious if there is another option using HA instead. I have spare RPIs or could load HA on a container but I’m not sure how to interface with the PLM and the Insteon switches. Ideally I’d like to not replace the switches.
Thanks in advance for any suggestions!
-Al
Buy new Home Assistant compatible dimmer switches to replace the Insteon dimmers, load HA on a Raspberry Pi, learn how to replace your ISY automations using HA automations (this is probably the most time consuming part).
FYI, this is what I did years ago.
Note the recommended minimum RPi specs: Installation - Home Assistant. I’ve been using a RPi 4b 4gb memory / 32gb SD without any issues for over 4 years now.
I appreciate the reply, @MaxK, but as I mentioned, I’m not sure that I want to replace the existing switches. They work perfectly fine. Looking into this further, I think it might be possible to connect a USB PLM to an HA controller and operate it from there. Does anyone have further guidance on this path?
Use this forums search function: “Insteon plm”
