Dave2
(Dave)
November 20, 2020, 4:59pm
1
While there is now an official Universal Devices ISY integration for Home Assistant, I found that it does not import Smart Meter information. I use this information to track daily energy usage and display instantaneous usage. To do this I wrote the following templates:
#ISY Main Meter
- platform: rest
resource: http://<your_isy_ip_address>/rest/emeter/metering/
json_attributes_path: "$.AMIMetering"
username: <your_username>
password: <your_password>
authentication: basic
headers:
Content-Type: text/xml
scan_interval: 30
value_template: 'OK'
json_attributes:
- "instantaneousDemand"
- "currDayDelivered"
I then create these two sensors:
main_meter_power:
device_class: power
friendly_name: "Main Meter"
unit_of_measurement: 'kW'
value_template: '{{ (states.sensor.isy_meter.attributes["instantaneousDemand"]["#text"] | int) / 1000 }}'
icon_template: mdi:mdi-current-ac
main_meter_energy_today:
device_class: energy
friendly_name: "Energy Imported Today"
unit_of_measurement: 'Wh'
value_template: '{{ (states.sensor.isy_meter.attributes["currDayDelivered"]["#text"] | int) }}'
works like a charm!
mike007
(Mike)
September 11, 2021, 12:41am
2
This is awesome, thanks for sharing!
I am interested in doing the same to monitor my PG&E power usage. PG&E lists the ISY994 ZS series as a “Validated” device compatible with their smartmeters.
So HA communicates with the ISY994 device over the LAN, correct? Does it have a wired ethernet port or wifi (or both?) Poking around a bit, it looks like it hardwires to the LAN. Anything else I should look out for?
Dave2
(Dave)
October 4, 2021, 5:27pm
3
Wired. I haven’t found any other devices that work with SCE but they may be out there.
phatmatt
(Matt)
December 15, 2021, 3:33am
4
Been a while since this was posted. Is it still working for you? Im having trouble with the sensors.
Im very new. Just copy and paste stuff. Dunno how to actually create or troubleshoot it.
thanks
Thank you for your work creating the templates/sensors. Those seem to be working great!
Were you able to integrate this into the HA energy dashboard? The sensors don’t pull up for me there.
Thanks!
Dave2
(Dave)
January 25, 2022, 1:26am
6
It’s been awhile since i’ve played with it so I had to look at my config file. It appears I modified it slightly to include state_class:
sensors:
main_meter_power:
device_class: power
unit_of_measurement: "kW"
icon_template: mdi:current-ac
attribute_templates:
last_reset: "{{ now().replace(hour=0, minute=0, second=0) }}"
state_class: measurement
unit_of_measurement: "Wh"
main_meter_energy_today_kwh:
friendly_name: "Energy Imported Today kWh"
unit_of_measurement: "kWh"
value_template: '{{ (states.sensor.isy_meter.attributes["currDayDelivered"]["#text"] | int) / 1000 }}'
It appears as an energy option but will require more testing to determine if it is accurate.
