FYI, I am getting an error on load.
2019-06-26 15:39:57 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for isy994 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-06-26 15:39:58 WARNING (MainThread) [homeassistant.components.http] Configuring api_password via the http component has been deprecated. Use the legacy api password auth provider instead. For instructions, see https://www.home-assistant.io/docs/authentication/providers/#legacy-api-password
2019-06-26 15:39:58 WARNING (MainThread) [homeassistant.components.http.auth] legacy_api_password support has been enabled.
2019-06-26 15:40:02 ERROR (MainThread) [homeassistant.setup] Error during setup of component person
File "/usr/src/homeassistant/homeassistant/setup.py", line 153, in _async_setup_component
hass, processed_config)
File "/usr/src/homeassistant/homeassistant/components/person/__init__.py", line 272, in async_setup
await manager.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/person/__init__.py", line 105, in async_initialize
raw_storage = await self.store.async_load()
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 81, in async_load
return await self._load_task
concurrent.futures._base.CancelledError
2019-06-26 15:40:02 ERROR (MainThread) [homeassistant.setup] Error during setup of component config
File "/usr/src/homeassistant/homeassistant/components/config/__init__.py", line 65, in async_setup
await asyncio.wait(tasks)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 363, in wait
return await _wait(fs, timeout, return_when, loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 456, in _wait
await waiter
2019-06-26 15:40:02 ERROR (MainThread) [homeassistant.setup] Error during setup of component script
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 60, in async_setup
await _async_process_config(hass, config, component)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 125, in _async_process_config
await component.async_add_entities(scripts)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 221, in async_add_entities
await waiter
2019-06-26 15:40:02 ERROR (MainThread) [homeassistant.setup] Error during setup of component sensor
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "uvloop/loop.pyx", line 1451, in uvloop.loop.Loop.run_until_complete
File "/usr/src/homeassistant/homeassistant/__main__.py", line 290, in setup_and_run_hass
log_no_color=args.log_no_color)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 188, in async_from_config_file
config_dict, hass, enable_log=False, skip_pip=skip_pip)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 92, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 411, in _async_set_up_integrations
for domain in domains_to_load
File "/usr/src/homeassistant/homeassistant/setup.py", line 50, in async_setup_component
return await task # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 126, in _async_setup_component
hass, config, integration)
File "/usr/src/homeassistant/homeassistant/config.py", line 668, in async_process_component_config
component = integration.get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 130, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 724, in exec_module
File "<frozen importlib._bootstrap_external>", line 860, in get_code
File "<frozen importlib._bootstrap_external>", line 791, in source_to_code
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/isy994/__init__.py", line 7
<!DOCTYPE html>
SyntaxError: invalid syntax
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 42, in async_setup
await component.async_setup(config)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 112, in async_setup
await waiter
