Hello Home Assistant team!
New HA user, going through the configs. I found a discrepancy I can’t rectify on my own.
On the Remote Access with TLS/SSL via Let’s Encrypt page there’s a big warning block of text which reads:
Before exposing your Home Assistant instance to the outside world it is ESSENTIAL that you have set a password following the advice on the [http](https://www.home-assistant.io/docs/configuration/basic/) page.
Unfortunately, on the http page there is no information regarding passwords.
Which password is this referring to? Maybe the legacy API authentication system? If that’s the case, it seems like references to needing a password should be removed from the “Remote Access with TLS/SSL via Let’s Encrypt” page.
Thanks in advance!
P.S. I would have added other links, but new users are restricted to 2 per post, it seems :).
