Hi
I have a lamp that turns blue when the temperature is below 4 degrees, but it only works when the yr sensor changes value.
My idea is that when I get up, the light turns on and should turn blue if there is frost outside, it can be slippery on the road
Make an automation that turns the light blue when you turn on the switch for the light.
I have an automation that turns on the light, so it should also see if the temp is below 4 degrees.
- alias: "Frostvejr"
platform: numeric_state
entity_id: sensor.vejr_temperature
below: 4.0
service: scene.turn_on
entity_id: scene.frost_pa_vej
`scene
- name: Frost på vej
entities:
light.spisebord:
state: on
brightness: 204
rgb_color: [18,27,255]
Yes. ALso, fyi use </> button in the text editor to display yaml correctly. The way you posted it is unreadable if people were to help you debug issues.
