Hi,i am new to HA.
I am not able to find itach integration.Need help.
You have probably looked at the document page
One sets this up in yaml as a remote:
integration using platform: itach
Which iTach do you have? Is it the IP2IR?
With the IP2SL I just use the telnet function to send the on/off commands to my projector through the iTach.
switch:
- platform: telnet
switches:
projector:
resource: ip address
port: 4999
command_on: "PWR ON\n"
command_off: "PWR OFF\n"
value_template: '{{ value == "PWR=01" }}'
timeout: 1
Thanks got this working
I will try this solution as well.
