I have a Russound CAV6.6 amplifier. I would like to be able to control it from HA. IR is a possibility if I had a remote or the IR codes but that would not show status (volume, source selected, etc.). Assuming I could control it using the Russound serial interface using an iTach WF2SL which bridges Wifi and serial, is there an integration for this application?
Thanks! That s the iTach IP to IR. I have the Wifi to Serial interface.
In that case you will have to use Global Cache’s API with shell commands.
You may be able to find some hints here: https://community.home-assistant.io/search?q=IP2SL
