BlackShift
(Thomas Jacquinot)
December 15, 2023, 3:57pm
1
Hi all,
I’m trying to integrate the data from my new gas meter into home assistant. This is the model they just installed:
https://www.metersit.com/en/products/residential-meters/domusnext-g4-169-en
I’m wondering if somebody had any luck with it ?
I’m going to trying playing with this:
I will report back if I find something. In the meantime, any advice is appreciated!
stewepylon
(Stewepylon)
January 24, 2024, 6:37pm
2
Hi Thomas,
have you got luck with it?
My house has the same Gas Meter series (Metersit G6 GPRS) and I was trying to get the data in HA.
Please, let me know what you discover so we can try to work together on it but from what I understand I’m already out because not having MBUS series…
Stefano
PxPert
(Pietro)
February 3, 2024, 11:40am
3
Please be aware that your G4 is using MBUS Narrowband which works on 169MhZ Frequencies. The im871A does only support mbus over 868MhZ, so it will not work.
You need to buy an AMB3665 dongle for that.
I’ve got a different Gas Meter (SamGas - Pietro Fiorentini) and already doing some research to decode the protocol (I’m already logging some telegrams, many of them from a metersit G4 like yours).
You can find my issue on wmusmeters github here:
opened 04:58PM - 02 Feb 24 UTC
device support
### Type of request
New device support
### Meter description
Please add suppo… rt for SamGas (Pietro Fiorentini) G4 N1A (169MhZ) devices.
This is the link of the product (With details both in italian and in English language)
https://www.fiorentini.com/it/soluzioni/prodotti/contatori-gas/contatori-gas-smart/rse-rsv/
I've got an Amber 3665 with some telegrams decoded (from my and my neighbours devices), attached in the next form.
I can log other telegrams if needed, or I can try to decode them by myselfs.
I can write C/C++ code but I don't know anything related to MBUS (Wired and wireless) protocols...
Thanks!
### Logged telegrams from meter in decrypted format
```shell
The Telegrams are for different Samgas meters, (Same model)
Received telegram from: 14050765
manufacturer: (SMG) Samgas, Italy (0x4da7)
type: Gas meter (0x03)
ver: 0x40
device: amb8465[00000000]
rssi: -47 dBm
driver: unknown!
telegram=|_4644A74D6507051440037DBF0001800101DB00333000000CC02884826CA25FA16CF5A194576E375B7871FD97168EDA33A7731EB6C01404D9B6658F26217267796F88297A478936|+397
(telegram) DLL L=46 C=44 (from meter SND_NR) M=4da7 (SMG) A=14055259 VER=40 TYPE=03 (Gas meter) (driver unknown!) DEV=amb8465[00000000] RSSI=-42
Received telegram from: 14055259
ver: 0x40
rssi: -42 dBm
driver: unknown!
telegram=|_4644A74D5952051440037DC90001800101DB00333000000CCBF2742B0E5C911E6F27B56BB53AE4E0BD5823AE4F4B92E2088F1AB2420F4A7B2D9A2289F6EEA84AE69C304E950040|+513
(telegram) DLL L=46 C=44 (from meter SND_NR) M=4da7 (SMG) A=15001221 VER=40 TYPE=03 (Gas meter) (driver unknown!) DEV=amb8465[00000000] RSSI=-103
Received telegram from: 15001221
ver: 0x40
rssi: -103 dBm
driver: unknown!
telegram=|_4644A74D2112001540037D484001800101DB003330000015D32CBE3058E15325A463E5A241D7D55EC40BFDF5990F71E607BF0EB065DE23B7B67A942E23EF4C4630E1511F3B79C6|+543
Received telegram from: 14054623
ver: 0x40
rssi: -36 dBm
driver: unknown!
telegram=|_4644A74D2346051440037DC90001800101DB00333000000CE8C856E73EFD262BC045EEA729529C7A9437B1ADF01E2B6F0F1FBD694E96541A3CA31BBCDDF444447E4992766C784C|+560
(amb8465) rssi 10 (-69 dBm)
(telegram) DLL L=46 C=44 (from meter SND_NR) M=4da7 (SMG) A=14052910 VER=40 TYPE=03 (Gas meter) (driver unknown!) DEV=amb8465[00000000] RSSI=-69
Received telegram from: 14052910
ver: 0x40
rssi: -69 dBm
driver: unknown!
telegram=|_4644A74D1029051440037DCA0001800101DB00333000000E56D6B49B7451EB79B8F8C7104766374864AB997DA758B9CFF6D3767E515438F9CAF8F60F6126E03AE3FFFC0DF35F0A|+1043
(telegram) DLL L=46 C=44 (from meter SND_NR) M=4da7 (SMG) A=15000503 VER=40 TYPE=03 (Gas meter) (driver unknown!) DEV=amb8465[00000000] RSSI=-73
Received telegram from: 15000503
ver: 0x40
rssi: -73 dBm
driver: unknown!
telegram=|_4644A74D0305001540037D714001800101DB00333000003088BA8BD6BF433592927E92736FAFB5DACC4A9A7261A0FE2A0A8A4A1379308AEAAE3D5B0E42348FE513C9A22DBC8503|+1131
BlackShift
(Thomas Jacquinot)
March 2, 2024, 6:43pm
4
I did not manage to get it to work… Probably PxPert is correct.
I’m tempted to use this other dongle, but it’s a bit expensive for a not so well documented use case that could lead nowhere…
BlackShift
(Thomas Jacquinot)
April 11, 2024, 10:34am
5
Hi, could you tell me what mode you are using, which gives you reading from the metersit G4. n1a, n1f… ? Thanks
gabrymed
(Gabriele)
April 22, 2024, 3:54pm
6
I’m interested in this device too
Iom
(livio)
December 27, 2024, 6:16pm
7
Hi! Someone was able to get it working? I have the same gas meter and interested too
andrewt81
(Andrewt81)
March 19, 2025, 8:13am
8
Any updates or developement? i have a Metersit G4 Mbus and really interested to integrate in my systems
