Samnang
(van Steen)
January 17, 2022, 8:33pm
1
Hi, I recently bought a ITead Sonoff Zigbee 3.0 USB Dongle. I have problems connecting this dongle to my Home Assistant installation.
I installed home assistant on a nuc using docker on ubuntu server 20.04. I start docker like this:
$ sudo docker run -d --name="home-assistant" --privileged --restart always -v /home/nerd/homeassistant/config:/config -v /etc/localtime:/etc/localtime:ro -v /dev:/dev -v /dev/ttyUSB0:/dev/ttyUSB0 --net=host ghcr.io/home-assistant/home-assistant:stable
This works flawlessly.
Both inside and outside the docker container the device is shown as:
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_76b207dc82c9eb11adf58f4f1d69213e-if00-port0
In the Home Assistant interface I try to add it as an integration. So I click on “Add integration” and choose “Zigbee home automation”. ZHA shows me the serial device path of the interface, which I select. After that I choose “ZNP” and it seems like Home Assistant starts to add it. However, in the end this final step fails and I get the message “Failed to connect”.
Does anyone know what I might be missing?
Kind regards,
Samnang
Samnang
(van Steen)
January 21, 2022, 6:45am
2
Just to add: I used the most recent firmware by Koenkk to flash the usb dongle.
$ wget https://github.com/Koenkk/Z-Stack-firmware/raw/master/coordinator/Z-Stack_3.x.0/bin/CC1352P2_CC2652P_launchpad_coordinator_20211217.zip
Today I flashed the dongle once more to see if something had gone wrong there, but alas: I still get the “Failed to connect” error.
What I did notice as well was that flashing my dongle takes less than a second to complete, where it seems to take longer in the video Easy Sonoff Zigbee CC2652 Firmware Upgrades! + Other Ethernet / USB - YouTube , in which digiblurDIY describes the flashing procedure.
Any pointers would be highly appreciated!
cstokes
(Clifton Stokes)
January 3, 2023, 1:48am
3
I am having the same issue with
Home Assistant 2022.12.8 Supervisor 2022.12.1 Operating System 9.4 Frontend 20221213.1 - latest
I have put the device on a USB extension and directly connected it to a USB port.
I have check that the firmware is the latest 6.10.x
Any ideas on what might be happening.
cstokes
(Clifton Stokes)
January 4, 2023, 12:41am
5
This is the error I get and nothing seems to help. Restarting. rebooting…
Any suggestion would be appreciated.
did you ever resolve this?
