coolspot18
(coolspot18)
November 3, 2022, 12:59am
21
I have pretty stable WiFi, are WiFi Serial coordinators really that unstable? Also some people mention that USB adapters are “faster”, is the response time poor on WiFi coordinators?
Hedda
(Hedda)
December 27, 2022, 12:15pm
22
FYI, jonasled created an ESPHome configuration for Sonoff ZBBridge-P bridge here on GitLab:
REGISTER TO GITLAB
It is in turn based on the ESPHome configuration from thegroove:
opened 10:20AM - 31 Jan 22 UTC
This request comes a little ahead of its time since this ITead Sonoff ZBBridge-P… is not available to buy yet, but it will be soon ;)
https://community.home-assistant.io/t/itead-sonoff-zbbridge-p-coming-soon-a-new-cc2652-and-esp32-based-sonoff-zigbee-bridge-and-sensors-from-itead-leaked-via-fcc/378924
UPDATE! ZBBridge-P (a.k.a. "ZB Bridge-P") has now been released as "SONOFF Zigbee Bridge Pro" as is now available for purchase:
https://itead.cc/product/sonoff-zigbee-bridge-pro/
FYI, FCC leak show CC2652P and ESP32 based Sonoff ZBBridge-P v1.1 Zigbee Bridge coming from ITead.
[https://fccid.io/2APN5ZBBRIDGEP](https://fccid.io/2APN5ZBBRIDGEP)
Internal pictures posted from FCC show using an unannounced Texas Intruments CC2652P (CC2652P1) MCU chip based “SM-031 v1.1” radio module which must be made by [CoolKit](https://github.com/CoolKit-Technologies/DevDocs/tree/master/Zigbee) (the company that makes their EFR32MG21 based “[SM-011 V1.0](https://www.coolkit.cn/product/sm-011/)” module).
ESP32 has replaced the ESP8266/ESP8285, and it also looks like added an on-board clock-battery too, presumably for RTC (Real-Time Clock)?
https://fccid.io/2APN5ZBBRIDGEP/Internal-Photos/Internal-Photos-5613131
FFC also leaked new Sonoff branded [Door/Window Sensor](https://fccid.io/2APN5SNZB-04P), [Motion Sensor](https://fccid.io/2APN5SNZB-03P), [Temp/Humidity Sensor](https://fccid.io/2APN5SNZB-02P), and a [Button](https://fccid.io/2APN5SNZB-01P) as wireless Zigbee devices, all with the same CCC2652P (CC2652P1/CC2652P1F) chip which +20 dBm capable power amplifier is really overkill for battery-operated sensors and should on theory use more battery power than if they would have used the compatible CC2652R or CC2652RB.
Sadly it looks like even this new variant of Sonoff ZBBridge still uses Wi-Fi instead of wired Ethernet network like the newer ZB-GW03:
[https://community.home-assistant.io/t/zb-gw03-ewelink-ethernet-zigbee-gateway-now-hacked-with-tasmota-zbbridge-so-can-be-used-via-mqtt-or-as-a-remote-zigbee-adapter-with-home-assistant-zha-and-zigbee2mqtt/341223](https://community.home-assistant.io/t/zb-gw03-ewelink-ethernet-zigbee-gateway-now-hacked-with-tasmota-zbbridge-so-can-be-used-via-mqtt-or-as-a-remote-zigbee-adapter-with-home-assistant-zha-and-zigbee2mqtt/341223)
Ethernet is preferred by DIY users who flash Tasmota or ESPHome in order to use it as a remote Zigbee adapter with ZHA or Zigbee2MQTT because tunnelling serial communication over a serial stream server connection and the serial APIs of the Zigbee stacks are not robust/stable over WiFi as assume a direct connection, which is why both ZHA and Zigbee warns against using WiFi-based networked-attached Serial-to-IP Zigbee bridges/gateways/adapters:
[https://www.home-assistant.io/integrations/zha#warning-about-wi-fi-based-zigbee-to-serial-bridgesgateways](https://www.home-assistant.io/integrations/zha#warning-about-wi-fi-based-zigbee-to-serial-bridgesgateways)
[https://www.zigbee2mqtt.io/advanced/remote-adapter/connect_to_a_remote_adapter.html](https://www.zigbee2mqtt.io/advanced/remote-adapter/connect_to_a_remote_adapter.html)
According to digiblur who broke this news, these are slated to be released in March of 2022:
[https://www.digiblur.com/2021/12/new-sonoff-zigbee-bridge-and-sensors.html](https://www.digiblur.com/2021/12/new-sonoff-zigbee-bridge-and-sensors.html)
Not sure if this is intended to permanently replace the popular ITead Sonoff ZBBridge
[https://community.home-assistant.io/t/sonoff-zbbridge-sonoff-zigbee-bridge-from-itead/187346](https://community.home-assistant.io/t/sonoff-zbbridge-sonoff-zigbee-bridge-from-itead/187346)
As I understand ITead have not abandoned Silicon Labs yet but it is just that Silabs chip stocks have suffered worse than most other companies during the still currently ongoing worldwide chip shortage.
PS: Assume it will use the same firmware for CC2652P as “Sonoff Zigbee 3.0 USB Dongle Plus”:
[https://community.home-assistant.io/t/sonoff-zigbee-3-0-usb-dongle-plus-by-itead-is-based-on-texas-instruments-cc2652p-can-now-be-ordered-for-10-99/340705/283](https://community.home-assistant.io/t/sonoff-zigbee-3-0-usb-dongle-plus-by-itead-is-based-on-texas-instruments-cc2652p-can-now-be-ordered-for-10-99/340705/283)
Giancky79
(G-man)
February 10, 2023, 9:57am
23
hi, i hope my configuration helping some one
vytis
(Vytis)
March 14, 2023, 5:31pm
24
Hey Guys, trying to set-up the ZBBrige-P with ZHA on my HA. There is very little info on the P version, and the guides for the non-P versions do not work “out of the box”. Anyway managed to get to the point where TCP ZBBridge Pro is running fine, however when I try to add it via ZHA I am getting a “failed to connect” error in HA. Tasmota console shows an attempt to connect from my HA IP address, however there it ends.
Any wise suggestions?
fullbl
June 21, 2023, 11:19am
25
vytis:
ZBBrige-P
I think it is not possible without flashing it before!
Giancky79
(G-man)
January 26, 2024, 5:15pm
26
@Hedda , i’m so happy, i have only one fix to make with esphome, but i don’t understand why. I need to enter in bsl mode for integrating with ZHA/Z2M
Giancky79
(G-man)
January 27, 2024, 2:36pm
27
ok, tonight from Italy, upload new code, all now working very well
