Itho daalderop HRU 400 modbus ESPhome
Hi All,
As a few others have attempted here:
https://gathering.tweakers.net/forum/list_messages/1976492/0
and here:
I also have a HRU 400, but without any fancy zones or whatever so the config will need adjusting!
The Manual can be found here:
(page 31 or section 6.2 if you want to help along :slight_smile: )
Generic modbus question:
For some reason I cannot get 40101 till 40104 (or 100 till 103) not to display any form of logical serial number that matches the serial number of the device. How would you go about reading these modbus values
HRU specific question:
As I do not have any fancy zones on the unit so I would need to play with these values to set the fan on / off:
register 42012 (2011) 0 seems to be the auto mode? and 1 seems to be set the fan to the value 1-399 where 399 is max cap. (register 2010) I dont see the logic here, also there is “ask for ventilation inlet” and “ask for ventilation outlet” which seem to do the same thing so not sure if you need to set them the same at the same time?
Thanks in advance for the help :slight_smile:
Did you ever figure this out?
I have the same setup: HRU400 w/o zones, connected via modbus.
I would like to control the ventilation level via home assistant, did you succeed?
Hey,
I sure did, its working great!
Even have a fan tile for the WTW.
The only down side is, if you control the WTW trough HA the external remotes no longer work.
This is a limitation in the firmware of the HRU400…
Added a bypas setting for the HRU 400:
# Bypass
  # 0 = down
  # 550 = open
  # Inside air is directed to the ourside without passing the heat exchanger
  # Thus cold outside air does not heat up from the hot inside air
  # Must be used with override mode to max 200 out of 399.. The unit should do this automatically...
  - platform: modbus_controller
    modbus_controller_id: hru
    name: "Bypass valve - on/off" # 0 = auto 1 = Manual
    register_type: holding
    address: 2033
    min_value: 0
    max_value: 1
    step: 1
    use_write_multiple: true
    icon: mdi:toggle-switch-variant
This still needs a automation in code that it also turns on your fan into manual mode and set it to 199 :slight_smile:
With:
    on_value_range:
      - above: 0.5
        then:
          - number.set:
              value: 199
      - below: 0.5
        then:
          - number.set:
              value: 0.0
It will turn the above code into an actual functioning bypass valve :slight_smile:
I you stumble upon this conversation.
Currently all code / control can be found here:
i was wondering if someone could help me out. I have an HRU400 with an ESP32S2 mini connected to the HRU via RS485-modbus. the connection works, i can control everything but i have an annoying error. Whenever i have a sequence of addresses in the yaml it all works e.g. 2021, 2022, 2023.
but whenever i have a gap in the addresses e.g. 2021, 2022, 2023, 2034 everything is messed up. values will be mixed from 1 address to the other and random changes in values will occur.
as you can see, the “outside air fan” got he value 550 which is the value of the bypass valve. the outside air fan has a range of 0-399 so it can never be 550.
here is my yaml:
esphome:
  friendly_name: itho-hru
esp32:
  board: lolin_s2_mini
  variant: esp32s2
  framework:
    type: arduino
#    version: 2.0.6
#    platform_version: 5.3.0
logger:
  level: DEBUG
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxx"
ota:
  - platform: esphome
    password: "xxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Itho-Hru Fallback Hotspot"
    password: "f0xSaMbuxcSi"
captive_portal:
web_server:
  port: 80
light:
  - platform: status_led
    icon: "mdi:alarm-light"
#    restore_mode: ALWAYS_OFF
    pin:
      number: GPIO15
      inverted: false
modbus:
  flow_control_pin: GPIO7
  uart_id: uart_modbus_hru
  #send_wait_time: 2000ms
uart:
  - id: uart_modbus_hru
    tx_pin: GPIO11 # should be GPIO11, cannot be swapped
    rx_pin: GPIO9 # should be GPIO9, cannot be swapped
    baud_rate: 19200 # should be 19200, 9600=no difference, 38400=no difference
    parity: EVEN #should be EVEN, ODD=no difference, NONE=does not work
    data_bits: 8
    stop_bits: 1
modbus_controller:
  - id: hru
    address: 0x49 #   original: 72 = 0x48, 73 = 0x49
    modbus_id: modbus_hru
    update_interval: 5s
    setup_priority: -10
    command_throttle: 200ms
    offline_skip_updates: 100
substitutions:
  skip_updates: "5"
  skip_updates_errors: "10"
  skip_updates_advanced: "100"
  modbus_id: hru
  max_cap: "399"
  flap_max: "550"
  alert_icon: mdi:alert-circle
  max_error_number: "5"
  fan_speed_1: "100"
  fan_speed_2: "150"
  fan_speed_3: "200"
  fan_speed_4: "250"
  fan_speed_5: "300"
  fan_speed_6: "350"
  fan_speed_7: "399"
# packages:
  # remote_package:
    # url: https://github.com/william-sy/esphome-Itho-Daalderop-HRU400
    # ref: main
    # refresh: 0s
    # files: [
      # # Step 1: Choose a language:
      # esphome/i18n/EN.yaml,
      # #esphome/i18n/NL.yaml,
      # # Step 2: Choose the board you bought:
      # #esphome/boards/board-esp32-atom-lite.yaml,
      # #esphome/boards/board-esp32-atom-s3-lite.yaml,
      # # Step 4: Configure the general stuff:
      # #esphome/base/base.yaml,
      # esphome/base/fan.yaml,
      # #esphome/base/select.yaml,
      # #esphome/base/bypass.yaml,
      # #esphome/base/frostvalve.yaml,
      # #esphome/base/advanced.yaml,
      # #esphome/base/faultcodes.yaml,
      # # Add a comma here if you enable zones:
      # #esphome/base/general.yaml
      # # Step 5: Enable aditional zones if you have them:
      # #esphome/zones/zone_1.yaml,
      # #esphome/zones/zone_2.yaml,
      # #esphome/zones/zone_3.yaml,
      # #esphome/zones/zone_4.yaml,
      # # Step 6: Dont forget to remove the last comma
number:
  - name: outside air fan demand value
    icon: mdi:home-import-outline
    address: 0x7DA #2021
    min_value: 0
    max_value: 399
    step: 1
    #initial_value: 0
    value_type: U_WORD
  #   use_write_multiple: true
  # #   # on_value_range:
  #     # - above: 2.0
  #       # then:
  #         # - number.set:
  #             # id: fan_demand_on_off
  #             # value: 1.0
  #     # - below: 1.0
  #       # then:
  #         # - number.set:
  #             # value: 0.0
  - name: Bypass position
    address: 0x7F0 #2032
    #value_type: U_WORD
    min_value: 0
    max_value: ${flap_max}
    step: 50
    #initial_value: 0
    modbus_controller_id: ${modbus_id}
    icon: mdi:valve
  - name: Bypass manual control on/off
    address: 0x7F1 #2033
    #value_type: U_WORD
    min_value: 0
    max_value: 1
    step: 1
    #initial_value: 0
the yaml above is with address gaps. you can see 2021, 2032 and 2033. then it goes wrong. whenever i comment out the 2021, the addresses are sequencial and the entities work again.
does anyone know how to solve this “gap” problem?
Use this:
send_wait_time: 500ms
With gaps you may need disable this:
Don’t use skip_updates it don’t work (still have bug?) and cause problems.
I only used modbus and number on this:
[[easyhan/esphome/t44-x04-soil.yaml at bf66f7420093fae44a5c152d52807c5a43550bc4 · nikito7/easyhan · GitHub]]
Hi All,
i finally found the solution. See this code. It’s only the first part of my yaml. It’s all about the framework version. This needs to be in de 2.x.x.x range. The comments after the lines are the results of tests i did to find the solution. The only thing that did anything was this framework version. I hope it helps someone.
esphome:
  name: esp-hru400 #uncommented
  friendly_name: esp-hru400 #uncommented
esp32:
  board: lolin_s2_mini #uncommented
  variant: esp32s2 #should be esp32s2
  framework: #uncommented
    type: arduino  #should be arduino
    version: 2.0.17 # only versions 2.x.x.x(x) work!!!!!!!!
Good day! First of all, I want to give my thanks and appreciation for sharing all the code on the HRU 400 project. I’ve been working on this mandatory project diligently for months, and I’m slowly (but surely) getting a set-up that I can use for Home Assistant automations. The last, but cumbersome, step is getting the quatro zones to work correctly. I have tried the github configuration provided by William, tried setting them up as covers (desperate…) and about a hundred different settings. I’m running Home Assistant in proxmox, and am working with the atom lite stack. When including the zone packages, I’m not getting the requested entities (only for Zone 1, but any changes made are directly set back to 0). The sensor.wtw_rs485_zone_flaps_connected does give state vlaue=15, so it seems to be recognising my flaps. I’m still very new to the whole coding, so any help is very welcome. If I ever create something that might be helpful, will share directly of course!
Great effort. I dont have zone flaps so I cant help you directly.
But if you figure those pages out feel free to share.
As for your settings going back to 0.
1: value=15, seems rather high… should be no more than 4?
2: In order to change any value, you probably need to change 42033 before you change 42034 same as 42011 has to be set first before you set 42010
(refer to the manual for the complete list of numbers)
Example: esphome-Itho-Daalderop-HRU400/esphome/base/fan.yaml at d083035615454af4cedf2afa91111043ca3b8ec3 · william-sy/esphome-Itho-Daalderop-HRU400 · GitHub
I am fairly new to HA and I don’t quite understand everything yet.
I have a HRU 400 with no zone flaps and I want to put it in my HA.
What do I need to do for this?
Can somebody give some instructions.
Kind regards.
Not sure if it will work for HRU-400; it is not mentioned, but have you had a look here ?
This wont work for a 400…
you will need this instead:
Shopping list but. from any other webshop will do:
When esphome 2025.6 is out i hope to improve the code on a few items :slight_smile:
Doesn’t have to be an Atom lite; any other ESPHome board with RS485 module will work too :wink:
Here my yaml:
substitutions:
  node_name: wtw-rs485 # Use a unique name.
  node_id: itho-hru400    # Use a unique id.
  friendly_node_name: WTW-RS485
esp32:
  board: esp32dev
  framework:
    type: esp-idf
    version:    recommended
esphome:
  comment: "Itho Daalderop HRU 400 WTW"
  # Make sure the WTW unit is in auto mode after updating the ESP.
  on_boot:
    priority: 600
    then:
      - number.set:
          # If you remove this, it will always restore to last set number and ignore the next.
          value: 0
      - switch.turn_off: fan_demand_on_off
      - switch.turn_off: bypass_valve_on_off
      - switch.turn_off: fan_flow_ingress_on_off
wifi:
  password: !secret wifi_iotpw
  power_save_mode: none
  manual_ip:
    static_ip: 192.168.3.55
    gateway: 192.168.3.254
    subnet: 255.255.255.0
  min_auth_mode: WPA2
  ap:
    ssid: ${node_name} FB
    password: "fallback"
captive_portal:
api:
  encryption:
    key: !secret api_encryption
# Enable Over The Air updates
ota:
  - platform: esphome
# Disable logging
logger:
  baud_rate: 0
  logs:
    sensor: ERROR
    duty_cycle: ERROR
    binary_sensor: ERROR
    light: ERROR
# Enable Web server.
web_server:
  port: 80
  version: 3
# Sync time with Home Assistant.
time:
  - platform: homeassistant
# Enable logging
logger:
packages:
  remote_package:
    ref: main
    refresh: 0s
    files: [
      # IMPORTANT SEE README -> https://github.com/william-sy/esphome-Itho-Daalderop-HRU400/blob/main/README.md
      # New board settings:
      # --> esphome/boards/uart/m5stack/U034/m5stack-C124-atom-s3-lite.yaml,
      # Legacy board settings:
      # --> esphome/boards/board-esp32-atom-lite.yaml,
      # --> esphome/boards/board-esp32-atom-s3-lite.yaml,
      # Or use your own, and set the correct uart tx/rx pins
      #and optional extra stuff
      # and don't forget to remove the last comma
    # Uart Settings
uart:
  tx_pin:       GPIO17
  rx_pin:       GPIO16
  baud_rate:    19200
  data_bits:    8
  stop_bits:    1
  parity:       EVEN
  debug:
    direction:  BOTH
True, the atom “tax” if you will is purely convenience.
No soldering, and it can be stuck to the side of the unit without bare PCB’s flying around :slight_smile:
