i would like to automate my bathroom fan Itho-Eco-fan in combination with an Aqara huminity sensor. I’ve already built this description:
I want to share some experience and code that i used to control a ITHO Daalderop CVE ECO-Fan.
This fan uses a RF protocol that is reverse engineerd by some clever people.
For reference i point to a dutch topic about it: https://gathering.tweakers.net/forum/list_messages/1690945/0
I developed a plugin for ESPEASY based on the library from this above forum by supersjimmie.
Sourcecode Plugin and Binary with plugin available at: GITHUB
Config:
- platform: mqtt
But now I would like to have it automatically controlled.
I wrote this automation but it doesn’t work:
#badkamer ventilatie
- id: fan.mechanical_ventilation
alias: 'Badkamer ventilatie'
platform: numeric_state
entity_id: sensor.lumi_lumi_weather_humidity
above: 65%
- service: switch.turn_on
entity_id: fan.set_speed
option: high
Who can help me? I have already looked for a bleuprint but couldn’t find one.
Bastiaan
Hi @Bastiaan1977
The state of the humidity is NOT 65% but 65 only, check in the DEVELOPER-STATES section for this sensor.
Hi @GH2user , in developer states I can see “unit_of_measurement” :%
So I thought that I have to wright 65%
Now I have changed it to 65 (without %) but no luck.
the code you are showing is not the whole part I guess?
The examples shown here https://www.home-assistant.io/docs/automation/trigger/ AND https://www.home-assistant.io/integrations/fan/ have a different format.
automation:
above: 65
- service: fan.set_speed
entity_id: fan.????
speed: high
Is the humidity under 65?
you can also check if the service call works using the DEVELOPER=SERVICES
FYI: the fan will get a major update in the next release of HA 2021.3 and high/low will be discarded in favor of numeric values.
Hi @GH2user , thanks for the support.
I got it done. with the two codes below, the fan works perfectly in combination with the aqara humidity sensor
alias: Badkamer ventilatie aan
- platform: numeric_state
above: '65'
entity_id: switch.stand_3
mode: single
- id: '1614778077800'
alias: Badkamer ventilatie uit
description: ''
below: '50'
condition: []
entity_id: switch.stand_1
mode: single
Thanks again
Gr.
Bastiaan
