Itho / Orco / Nuaire: Fan metrics, Remote control & Sensor faking via RF
The evohome_rf custom integration has morphed into ramses_rf and now supports HVAC in addition to CH/DHW at a relatively mature level:
I feel is worth announcing in a separate thread, to increase the visibility of this project for HVAC people.
This means, for ventilation units compatible with Itho / Orco / Nuaire RF-based systems (HRUs, CVEs, & PIVs) using the RAMSES_II protocol, you can:
  • monitor ventilation unit metrics, e.g. fan speed, air flow rate, fan mode, CO2 level, humidity, etc.
  • fake CO2 / humidity sensors (other sensors coming soon, e.g. PIR) with any HA-aware sensor
  • control ventilation remotes: mode (.e.g. speed, auto, away, etc.), bypass mode, etc.
For this integration, you’ll need a USB dongle running evofw3, such as this one (you can make them yourself, or source them elsewhere).
Photos coming!
I am currently running the latest master. Works really well. My overview to control the fan:
afbeelding
and the CO2 overview (with entity names removed):
afbeelding
Here you see the automatic bypass of an Orcon HRU in action, first image is the measured air flow, second one some temperatures (all taken from the HRU):
To add to the nice graphs:
A graph showing supply flow (in wrong units, fixed in the latest release) and CO2 level of the CO2 remote driving the fan. Note the heavy oscillations. I’m working on fixing this, but these graphs help a lot!
The square wave around 18:00 is from using setting 3 (1 hour max flow) for cooking. Around 23:00 we when to bed and the CO2 starts rising.
I am thinking of adding probing - the system eavesdrops, and picks up fans/remotes/sensors (you can facilitate this by pushing buttons on your remote) - then probing the fan to:
  • determine if Orcon, Itho or Nuaire scheme
  • determine modes supported by the ventilation unit
  • automatically adding those modes to either a Remote / Fan or HVAC entity (I haven’t decided yet, which)
The issue here is that the probing will make the ventilation (e.g.) change fan speed, etc. - so would best be a service call?
Thoughts?
If I understand you correctly, you want to ask the user to do a single button press, and then probe the addressed fan with all known commands for the detected fan scheme by impersonating the remote?
Can’t you determine the model of the remote, sensor or fan based on their ID packets, and derive the supported commands from them? That feels safer… but it does add the burden of managing some sort of capabilities database to the software.
So I have a Nuaire PIV Eco-Dri system. if I was to set this up how do I get it to start listening in on the RF signals. do I set it to a pairing mode for the button units? I have wanted to be able to control this unit remotely for ages.
See posts above. They failed to get this working only because their PIV did not support RF.
If the PIV does support PIV then this is doable
  • it will listen/discover the FAN by default
  • you will have to create (and likely bind) a faked remote
I believe you are referring to the other thread, here.
My understanding is it does support RF as it can take the RF remotes 2 and 4 way. just wanted to know how it then discovers the fake remote.
What you want should be straight-forward.
I have a Nuaire 4-way connected to my PIV that I bound years ago. Relatively recently, I have been simply impersonating that 4-way with a faked remote.
The RF dongle you require will be a lot cheaper that the 4-way switch, and you have the added advantage of HA sensors, etc.
You will have to do the binding with the faked remote - you put the PIV in binding mode and press/hold boost on the 4-way - you do that via HA service call.
You’ll need to edit the configuration.yaml file too.
All the code for the above is in place, although if there is a problem, I can look at it for you.
There is no reason why ramses_cc can’t be used to impersonate a humidity sensor too - although this is a WIP - it would be eaiser to use an automation to trigger a boost when a humidity sensor rises above a set level.
Thanks for that. sounds great. as you say going to be alot cheaper than a £90 4 Way and I get HA Automation, remote access to it ETC.
Any recommendations for the right RF sensor options available in the UK? the one linked is out of stock. I can then get this setup and working.
Perhaps ask on the other thread: Honeywell CH/DHW via RF - evohome, sundial, hometronics, chronotherm - Share your Projects! - Home Assistant Community (home-assistant.io)
(Moved this over from Honeywell CH/DHW via RF - evohome, sundial, hometronics, chronotherm - #4616 by hermanb).
Hi, I’m new to this CH/DHW/HVAC scene and installed a ORCON HRC 400 myself. I own a simple 6 button Orcon remote, but like to bind it to HA and control things like the bypass and fan level with automations.
Great work on ramses. There is a lot of documentation. However, after reading nearly all of it, and understanding half of it, I still struggle to bind faked sensors, and to control my setup. The Config Flow change hasn’t helped: most documentation refers to the old YAML approach and the mapping isn’t 100% clear nor validated. However, my real issues are with ‘magic’ parameters like device_info. The docs (5.2 Faking Remotes (switches) · zxdavb/ramses_cc Wiki · GitHub) contain a table with device_info payload, but the actual actions use a longer I/W sequence that somehow seems to adds some fields. Can someone point me at how to understand & formulate those payloads?
It would be great if there was some registry/wizard combination that contains dummy-proof controls that help with what is always the same, what was reversed engineered already, and what must be learned or gathered by the user themselves.
My Config Flow configuration is now the equivalent of the following.
ramses_cc:
  orphans_hvac:
    - "32:133288"
    - "29:168696"
    - "32:114444"
    - "32:116666"
    - "29:123456"
  known_list:
    "32:133288":
        class: FAN
        _note: Orcon HRC 400
    "29:168696":
        class: REM
        _note: Orcon remote
    "32:114444":
        class: CO2
        faked: true
        _note: CO2 sensor
    "32:116666":
        class: HUM
        faked: true
        _note: humidity sensor
    "29:123456":
        class: REM
        faked: true
        _note: based upon an Orcon 15RF 6-button remote (VMN-15LF01)
        commands:
            away: " I --- 29:123456 32:133288 --:------ 22F1 003 000007"
            low: " I --- 29:123456 32:133288 --:------ 22F1 003 000107"
            medium: " I --- 29:123456 32:133288 --:------ 22F1 003 000207"
            high: " I --- 29:123456 32:133288 --:------ 22F1 003 000307"
            auto: " I --- 29:123456 32:133288 --:------ 22F1 003 000407"
            auto2: " I --- 29:123456 32:133288 --:------ 22F1 003 000507"
            boost: " I --- 29:123456 32:133288 --:------ 22F1 003 000607"
            disable: " I --- 29:123456 32:133288 --:------ 22F1 003 000707"
            bypass_open: " W --- 29:123456 32:133288 --:------ 22F7 003 00C8EF"
            bypass_close: " W --- 29:123456 32:133288 --:------ 22F7 003 0000EF"
            bypass_auto: " W --- 29:123456 32:133288 --:------ 22F7 003 00FFEF"
            reset_filter: " W --- 29:123456 32:133288 --:------ 10D0 002 00FF"
I’m yet trying to figure our how to bind those 3 fakes. I know that the following is incomplete, because offer isn’t set (and I don’t know how to create an offer):
type: button
tap_action:
  action: call-service
  service: ramses_cc.bind_device
    device_id: "29:123456"
    offer: ?
    device_info: ?
I have the same problem; when I go into developer tools - action and try to bind my fake remote to my Orcon HRC450 ecomax (see below), I get an error from the ramses_cc_bind_device: Actie ramses_cc.bind_device kon niet worden uitgevoerd. Unknown error…
action: ramses_cc.bind_device
  offer:
    "22F1":
    "22F3":
    "10E0":
  device_info: " I --- 29:123456 32:138460 --:------ 10E0 038 000001C894030167FFFFFFFFFFFF1B0807E4564D492D313557534A3533000000000000000000"
Below are my system schemes:
orphans_hvac:
  - "18:221588"
  - "32:138460"
  - "32:133440"
  - "37:018917"
  - "29:123456"
And known ID’s:
"18:221588":
  _note: ramses_esp
  class: HGI
"29:123456":
  _note: Orcon 15RF (virtual)
  class: REM
  commands:
    auto: " I --- 29:123456 32:138460 --:------ 22F1 003 000407"
    auto2: " I --- 29:123456 32:138460 --:------ 22F1 003 000507"
    away: " I --- 29:123456 32:138460 --:------ 22F1 003 000007"
    boost: " I --- 29:123456 32:138460 --:------ 22F1 003 000607"
    bypass_auto: " W --- 29:123456 32:138460 --:------ 22F7 003 00FFEF"
    bypass_close: " W --- 29:123456 32:138460 --:------ 22F7 003 0000EF"
    bypass_open: " W --- 29:123456 32:138460 --:------ 22F7 003 00C8EF"
    disable: " I --- 29:123456 32:138460 --:------ 22F1 003 000707"
    high: " I --- 29:123456 32:138460 --:------ 22F1 003 000307"
    high_15: " I --- 29:123456 32:138460 --:------ 22F3 007 00120F03040404"
    high_30: " I --- 29:123456 32:138460 --:------ 22F3 007 00121E03040404"
    high_60: " I --- 29:123456 32:138460 --:------ 22F3 007 00123C03040404"
    low: " I --- 29:123456 32:138460 --:------ 22F1 003 000107"
    med_60: " I --- 29:123456 32:138460 --:------ 22F3 007 00123C02040404"
    medium: " I --- 29:123456 32:138460 --:------ 22F1 003 000207"
    request10D0: RQ --- 32:133440 32:138460 --:------ 10D0 001 00
    request31DA: RQ --- 29:123456 32:138460 --:------ 31DA 001 00
    reset_filter: " W --- 29:123456 32:138460 --:------ 10D0 002 00FF"
  faked: true
"32:133440":
  alias: Orcon WTW zoneklep (boven)
  class: HGI
"32:138460":
  _note: Orcon WTW Fan
  bound: "29:123456"
  class: FAN
"37:018917":
  alias: Orcon CO2 meter (studeerkamer)
  class: CO2
Does anyone know what to do? Thanks!!
The WTW has to be in binding mode to succeed the binding process. Once it’s in binding mode, it would most likely accept the settings.
Thanks for the reply, already tried it but will try again…
