It's alive
Anyone had problems with automation - since yesterday, any automation that runs goes into a loop. Lights turning on/off, same with switches.
I have an automation which sends me telegram message - I have 830 messages. I turned the system off.
Never seen anything like this.
Nope all good here. Check your logs.
Without looking at the logs, realised what I had done - setup a remote_home assistant which seemed to make the system go into a loop.
You overlooked to mention that in your first post. It makes it challenging to provide assistance if important details aren’t revealed. As a consequence, the usual reply to a broad question containing few details is typically ‘check logs’ and/or ‘what did you change recently’.
Glad to hear you found the cause of the problem.
