It's possible to use the old automation interface?
Hi all
Although Home Assistant is the best home automation, the new automation interface requires too many clicks, it was much simpler before, it gets messy.
Being able to choose a less assisted mode would be appreciated.
Is this a feature being considered ?
  • Core2024.1.3
  • Supervisor2023.12.0
  • Operating System11.4
  • Interface utilisateur20240104.0
Writing automations in yaml is less assisted.
Try using the search, it decreases the overall difference in clicks between old and new interfaces especially in the action block since you can breeze through service calls.
Thanks for your answer.
Yes it’s true, but for recent users it’s quite difficult at start.
Totally agree. But since using yaml is really needed to build complex setups with lots of repeating code - I would suggest to start learning on examples generated by UI - and then switch to yaml step by step.
