Its winther, blockheater funktion!
Hi, I have made a blockheater function where you kan use several sockets and temperature sensors.
I hope it will be useful to someone.
Feel free to ask if there is something that dont work.
Download the file in the end to get the right format.
Regards Andreas
Car heater package for multi sockets
Source https://github.com/Danielhiversen/home-assistant_config/blob/master/packages/alarm_clock.yaml
And seriksson at Car Heater (winter is coming) need coding help!
Great thank to all involved
################################################## How to Use ###############################################################
I have divided my configuration in a separate file, information about how to do this can be found on www.home-assistant.io.
Number of engine heat outputs you add or remove in group and input_select.
All names and friendly_name are in swedish, change to what you want.
There are 5 different levels that trigger from +5 to -15 °C
You have to add id number to automations and change entity_id in blockheater_group.
My automations and blockheater_val trigger “switch.blockheaterXXX_switch”, where blockheaterXXX comes from blockheater_val.
Any improvements or faults are gladly accepted
Use this as you like
#Automations
  • alias: heater minus 15
    initial_state: false
    • platform: time
      minutes: ‘/5’
      seconds: ‘2’
      condition:
    • condition: numeric_state
      entity_id: sensor.temp_heater
      below: ‘-15’
    • condition: template
      value_template: ‘{{ ((now().strftime("%s") | int + 7200) | timestamp_custom("%H:%M")) == states(“sensor.departuretime”) }}’
    • service: script.turn_on
      entity_id: script.heat_on
    • service: notify.xxxxxxxxxx
    change to notify service of your choise
    data_template:
    message: “{{ states(‘input_select.blockheater_val’) }} är på i 2h from {{ now().strftime(’%H:%M’) }} Temp: {{ states(‘sensor.temp_heater’) }}°C”
    • service: homeassistant.turn_off
      entity_id:
      • automation.heater_minus_15
      • automation.heater_minus_10
      • automation.heater_minus_5
      • automation.heater_nollan
      • automation.heater_plus_5
  • alias: heater minus 10
    • platform: time
      minutes: ‘/5’
      seconds: ‘2’
      condition:
      below: ‘-10’
      value_template: ‘{{ ((now().strftime("%s") | int + 5400) | timestamp_custom("%H:%M")) == states(“sensor.departuretime”) }}’
    • service: notify.xxxxxxxxxxx
    data_template:
    message: “{{ states(‘input_select.blockheater_val’) }} är på i 1,5h from {{ now().strftime(’%H:%M’) }} Temp: {{ states(‘sensor.temp_heater’) }}°C”
      entity_id:
  • alias: heater minus 5
    • platform: time
      minutes: ‘/5’
      seconds: ‘2’
      condition:
      below: ‘-5’
      value_template: ‘{{ ((now().strftime("%s") | int + 3600) | timestamp_custom("%H:%M")) == states(“sensor.departuretime”) }}’
    data_template:
    message: “{{ states(‘input_select.blockheater_val’) }} är på i 1h from {{ now().strftime(’%H:%M’) }} Temp: {{ states(‘sensor.temp_heater’) }}°C”
      entity_id:
  • alias: heater nollan
    • platform: time
      minutes: ‘/5’
      seconds: ‘2’
      condition:
      below: ‘0’
      value_template: ‘{{ ((now().strftime("%s") | int + 2700) | timestamp_custom("%H:%M")) == states(“sensor.departuretime”) }}’
    data_template:
    message: “{{ states(‘input_select.blockheater_val’) }} är på i 45 min from {{ now().strftime(’%H:%M’) }} Temp: {{ states(‘sensor.temp_heater’) }}°C”
      entity_id:
  • alias: heater plus 5
    • platform: time
      minutes: ‘/5’
      seconds: ‘2’
      condition:
      below: ‘5’
      value_template: ‘{{ ((now().strftime("%s") | int + 1800) | timestamp_custom("%H:%M")) == states(“sensor.departuretime”) }}’
    data_template:
    message: “{{ states(‘input_select.blockheater_val’) }} är på i 30 min from {{ now().strftime(’%H:%M’) }} Temp: {{ states(‘sensor.temp_heater’) }}°C”
      entity_id:
  • alias: heater enabled
    platform: state
    entity_id: input_number.heater_hour, input_number.heater_minutes, input_select.blockheater_val
    • service: homeassistant.turn_on
      entity_id:
  • alias: heater off
    • platform: time
      minutes: ‘/5’
      seconds: ‘2’
      condition:
      value_template: ‘{{ now().hour == (states.input_number.heater_hour.state | round(0)) and now().minute == (states.input_number.heater_minutes.state | round(0) ) }}’
    • service: switch.turn_off
      entity_id: switch.block_heater
      entity_id:
      • automation.heater_off
    • service: notify.kroksta_hass
    data_template:
    message: “Motorvärmare stängs nu av {{ now().strftime(’%H:%M’) }} Temp: {{ states.sensor.temp_heater.state }}°C”
    change message to language of your choise
#Groups
heater_disable:
entities:
- automation.heater_minus_15
- automation.heater_minus_10
- automation.heater_minus_5
- automation.heater_nollan
- automation.heater_plus_5
heater_all:
entities:
- input_select.blockheater_val
- group.heater_disable
- sensor.departuretime
- input_number.heater_hour
- input_number.heater_minutes
- sensor.temp_heater
- switch.block_heater
blockheater_group:
entities:
- switch.your_switch1
- switch.your_switch2
- switch.your_switch3
#Add or remove to suit your setup
#Input_select
blockheater_val:
options:
  • blockheater_1
  • blockheater_2
  • blockheater_3
    #add or remove to suit your setup
    icon: mdi:engine
    #Input_number
    heater_hour:
    icon: mdi:timer
    initial: 07
    min: 0
    max: 23
    step: 1
heater_minutes:
icon: mdi:timer
initial: 30
min: 0
max: 55
step: 5
#script
heat_on:
alias: heater_on
sequence:
  • service: switch.turn_on
  • service: automation.turn_on
    entity_id: automation.heater_off
    #sensor
    temp_heater:
    friendly_name: “Temperatur”
    value_template: >
    {% if is_state(‘input_select.blockheater_val’, ‘blockheater_3’) %}
    {{ states.sensor.your_temo_sensor1.state }}
    {% else %}
    {{ states.sensor.your_temp_sensor2.state }}
    {% endif %}
    #I have set up one blockheater inside my garage and the other is outside. If you have more or less sockets to control change it here
    #switch
    block_heater:
    friendly_name: “Motorvärmaren PÅ/AV”
    value_template: “{{ is_state(‘group.blockheater_group’, ‘on’) }}”
    turn_on:
    data_template:
    entity_id: “switch.{{ states(‘input_select.blockheater_val’) }}_switch”
    turn_off:
    data_template:
    icon_template: >-
    {% if is_state(‘group.blockheater_group’, ‘off’) %}
    mdi:engine-outline
    {% else %}
    mdi:engine
    {% endif %}
    mv_all:
    value_template: “{{ states.group.heater_disable.state }}”
    turn_on:
    entity_id: group.heater_disable
    turn_off:
    icon_template: >-
    {% if is_state(‘group.heater_disable’, ‘off’) %}
    mdi:engine-outline
    {% else %}
    mdi:engine
    {% endif %}
Blockheater multi.yaml (9.6 KB)
