The homeassistant itunes integration creates a functional media player, so this part is working.
I can control the play/pause/forward/reverse/volume of the primary mediaplayer.
The integration also creates mediaplayers for each of the airplay endpoints on my network, and updates their status correctly (ie, on / off /volume). However, these airplay endpoints cannot be controlled in homeassistant. For example, on/off/volume of each airplay endpoint can only be controlled from the music app, not from homeassistant.
Is anyone else using this successfully?
It has been several years since the iTunes api has been updated, are any developers interested in taking a look at this?
Thank you!
Thinking more about this, is the Apple TV integration able to interface with the Music app on a mac?
It seems that an integration that emulates apple’s itunes remote app would fit this purpose.
It is alive and kicking for me. I did make a couple of additional tweaks to the DrMachin version, but honestly don’t remember exactly what, but I don’t think it would impact the airplay endpoints.
I did have something strange happen the other day that may be related. I have been monkeying around with the ATV integration to do some TTS to some HomePods. Shortly after I added those, the connection to the airplay receivers from the iTunes integration did exactly what you described. I uninstalled/re-installed the iTunes api and apple music on my server and everything is back to normal. Even with my super geeky TTS notifications working. So perhaps there is some hope.
I too am hoping for a better solution to integrate Apple Music. I have anxiety attacks every time I update the macOS praying that it doesn’t break the iTunes api. I don’t have the skills to take over maintenance of the integration or the api. I am far too invested in the apple ecosystem to even contemplate a change.
Just went back and checked and I did make a change to airplay.js that may have an impact. You can see the changes on my branch https://github.com/chasut/itunes-api
UnfortunateIy my branch may not work as is. I also made some changes to the home-brew path and restart so that it forever works properly. But I think that is because I screwed up my home-brew install
Thanks for sharing that the integration is working for you, including the airplay endpoints.
I’ll try to see what’s up with my installation of iTunes-api.
I would very much like to use this integration. To my shame, I must admit that I am unfortunately completely unable to get it to work. I have completed the HomeAssistant part (media_player in configuration.yaml file including the IP address of my Mac). But what exactly do I need to do on the Mac side to make the API work? Is there a step-by-step guide? Or can one of you help me? What exactly do I need to do?
